open_source:ccgx:commandline
open_source:ccgx:commandline [2019-06-22 20:47] – [1. Introduction] mvader | open_source:ccgx:commandline [2021-03-06 14:38] – [8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub)] mvader | ||
Line 12: | Line 12: | ||
Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | ||
- | In case of questions, you can use the [[https:// | + | In case of questions, you can use the [[https:// |
Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
Line 23: | Line 23: | ||
Line 39: | Line 39: | ||
==== 1.3 Connecting to the command line and file transfer ==== | ==== 1.3 Connecting to the command line and file transfer ==== | ||
Line 133: | Line 133: | ||
- | Then transfer the new file back onto the [[venus-os: | + | Then transfer the new file back onto the [[venus-os: |
Line 144: | Line 144: | ||
Line 156: | Line 158: | ||
Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | ||
- | Make sure that the [[venus-os: | + | Make sure that the [[venus-os: |
Line 341: | Line 343: | ||
Victron Energy B.V. | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
Line 407: | Line 431: | ||
- If you want to set a password, go to Settings -> Remote Console -> Enable password check | - If you want to set a password, go to Settings -> Remote Console -> Enable password check | ||
- | ===== 8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub) ===== | ||
- | If you have a CCGX already installed, but VRM two-way communication is not enabled, follow these steps to enable it remotely: | ||
- | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - VE.Configure should now be able to connect to the CCGX | ||
