open_source:ccgx:commandline
open_source:ccgx:commandline [2019-06-22 15:25] – [1. Introduction] mvader | open_source:ccgx:commandline [2021-03-03 10:14] – [4.4 vreg: changing settings from the command line] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
- | To get started on Venus OS, start [[https:// | + | For more software developer oriented command line tips & tricks, see [[https:// |
==== 1.1 No support warning ==== | ==== 1.1 No support warning ==== | ||
Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | ||
- | In case of questions, you can use the [[https:// | + | In case of questions, you can use the [[https:// |
Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
Line 23: | Line 23: | ||
Line 39: | Line 39: | ||
==== 1.3 Connecting to the command line and file transfer ==== | ==== 1.3 Connecting to the command line and file transfer ==== | ||
Line 133: | Line 133: | ||
- | Then transfer the new file back onto the [[venus-os: | + | Then transfer the new file back onto the [[venus-os: |
Line 144: | Line 144: | ||
Line 156: | Line 158: | ||
Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | ||
- | Make sure that the [[venus-os: | + | Make sure that the [[venus-os: |
Line 340: | Line 342: | ||
Victron Energy B.V. | Victron Energy B.V. | ||
+ | Example of switching a solar charger off, and then on | ||
+ | OFF: (vreg 0x0200, value 4) | ||
+ | ccgx:~# vreg -n 0x45 -s 0x0200 un8:0x04 | ||
+ | # NAD 0x45, reg=0x200 | ||
+ | 0x04 0x00 0x00 0x00 | ||
+ | ON: (vreg 0x0200, value 1) | ||
+ | root@ccgx: | ||
+ | 0x01 0x00 0x00 0x00 | ||
+ | root@ccgx: | ||
+ | Gets can be broadcasted, | ||
+ | vreg -c socketcan: | ||
+ | root@einstein: | ||
+ | # reminder, there are no error indications when broadcasting! | ||
+ | # NAD 0x24, reg=0x200 | ||
+ | # NAD 0x25, reg=0x200 | ||
+ | # NAD 0x26, reg=0x200 | ||
+ | and so forth | ||
===== 5. VE.Direct products ===== | ===== 5. VE.Direct products ===== |
