open_source:ccgx:commandline
open_source:ccgx:commandline [2019-04-15 21:10] – [5. VE.Direct products] mvader | open_source:ccgx:commandline [2022-09-15 10:27] – [4.3 Restarting a VE.Can device] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
+ | For more software developer oriented command line tips & tricks, see [[https:// | ||
==== 1.1 No support warning ==== | ==== 1.1 No support warning ==== | ||
Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | ||
- | In case of questions, you can use the [[https:// | + | In case of questions, you can use the [[https:// |
Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
Line 22: | Line 23: | ||
Line 38: | Line 39: | ||
==== 1.3 Connecting to the command line and file transfer ==== | ==== 1.3 Connecting to the command line and file transfer ==== | ||
Line 132: | Line 133: | ||
- | Then transfer the new file back onto the [[venus-os: | + | Then transfer the new file back onto the [[venus-os: |
Line 143: | Line 144: | ||
Line 155: | Line 158: | ||
Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | ||
- | Make sure that the [[venus-os: | + | Make sure that the [[venus-os: |
Line 280: | Line 283: | ||
UDF is ready to accept update. | UDF is ready to accept update. | ||
Udf enabled, update can begin. | Udf enabled, update can begin. | ||
+ | ->> NOTE THAT IT CAN ALSO HAPPEN THAT THE -u COMMAND RETURNS AN ERROR. WHICH IS NORMAL. YOU | ||
+ | CAN VERIFY IF IT WAS SUCCESSFULL BY RUNNING JUST vup. IT WILL SHOW ALL DEVICES AND INDICATE | ||
+ | IF THEY ARE IN BOOTLOADER MODE (-u WAS SUCCESSFULL) OR NOT | ||
root@ccgx: | root@ccgx: | ||
Line 340: | Line 347: | ||
Victron Energy B.V. | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
Line 399: | Line 428: | ||
- SSH into CCGX (make a root password by following instructions [[ccgx: | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - < | + | - Enable Remote Console on LAN: < |
- | - < | + | - Create the password file. Empty file means no password: |
- Reboot CCGX via SSH: < | - Reboot CCGX via SSH: < | ||
- Now you should be able to access Remote Console feature from VRM | - Now you should be able to access Remote Console feature from VRM | ||
- If you want to set a password, go to Settings -> Remote Console -> Enable password check | - If you want to set a password, go to Settings -> Remote Console -> Enable password check | ||
- | ===== 8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub) ===== | ||
- | If you have a CCGX already installed, but VRM two-way communication is not enabled, follow these steps to enable it remotely: | ||
- | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - VE.Configure should now be able to connect to the CCGX | ||
