open_source:ccgx:commandline
open_source:ccgx:commandline [2018-12-06 13:16] – guy_stewart | open_source:ccgx:commandline [2021-03-03 11:46] – [4.4 vreg: changing settings from the command line] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
+ | For more software developer oriented command line tips & tricks, see [[https:// | ||
==== 1.1 No support warning ==== | ==== 1.1 No support warning ==== | ||
Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | ||
- | In case of questions, you can use the [[https:// | + | In case of questions, you can use the [[https:// |
Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
Line 22: | Line 23: | ||
Line 38: | Line 39: | ||
==== 1.3 Connecting to the command line and file transfer ==== | ==== 1.3 Connecting to the command line and file transfer ==== | ||
Line 132: | Line 133: | ||
- | Then transfer the new file back onto the [[venus-os: | + | Then transfer the new file back onto the [[venus-os: |
Line 143: | Line 144: | ||
Line 155: | Line 158: | ||
Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | ||
- | Make sure that the [[venus-os: | + | Make sure that the [[venus-os: |
Line 285: | Line 288: | ||
+ | # vreg --help | ||
+ | -b,--bin | ||
+ | -g,--get | ||
+ | Get a register. | ||
+ | -n,--nad | ||
+ | -r,--run | ||
+ | Keep running. | ||
+ | -s,--set | ||
+ | COMMON OPTIONS: | ||
+ | -c, --canbus | ||
+ | -d, --dump | ||
+ | -h, --help | ||
+ | Print this help. | ||
+ | --log-before < | ||
+ | --log-after < | ||
+ | Like -log-before, | ||
+ | --silent | ||
+ | -v --verbose | ||
+ | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
- | List all services running: | + | ==== 5.1 See connected devices ==== |
+ | # svstat /service/* | grep vedirect | ||
- | svstat /service/* | + | ==== 5.2 Firmware update ==== |
- | Look for the product that you want to update, and claim the serial port: | + | First stop the driver: |
Line 322: | Line 408: | ||
+ | See here: https:// | ||
