open_source:ccgx:commandline
open_source:ccgx:commandline [2018-12-06 13:16] – guy_stewart | open_source:ccgx:commandline [2019-06-22 20:47] – [1. Introduction] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
+ | For more software developer oriented command line tips & tricks, see [[https:// | ||
==== 1.1 No support warning ==== | ==== 1.1 No support warning ==== | ||
Line 284: | Line 285: | ||
Querying devices | Querying devices | ||
+ | # vreg --help | ||
+ | -b,--bin | ||
+ | -g,--get | ||
+ | Get a register. | ||
+ | -n,--nad | ||
+ | -r,--run | ||
+ | Keep running. | ||
+ | -s,--set | ||
+ | COMMON OPTIONS: | ||
+ | -c, --canbus | ||
+ | -d, --dump | ||
+ | -h, --help | ||
+ | Print this help. | ||
+ | --log-before < | ||
+ | --log-after < | ||
+ | Like -log-before, | ||
+ | --silent | ||
+ | -v --verbose | ||
+ | Victron Energy B.V. | ||
- | List all services running: | + | ==== 5.1 See connected devices ==== |
+ | # svstat / | ||
- | Look for the product that you want to update, and claim the serial port: | + | ==== 5.2 Firmware |
+ | First stop the driver: | ||
Line 322: | Line 384: | ||
+ | See here: https:// | ||
