open_source:ccgx:commandline
open_source:ccgx:commandline [2018-07-10 08:25] – mvader | open_source:ccgx:commandline [2021-03-03 10:14] – [4.4 vreg: changing settings from the command line] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a Venus device, for example the Color Control GX, via the command line, ie ssh. | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
+ | For more software developer oriented command line tips & tricks, see [[https:// | ||
==== 1.1 No support warning ==== | ==== 1.1 No support warning ==== | ||
Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; | ||
- | In case of questions, you can use the [[https:// | + | In case of questions, you can use the [[https:// |
Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
Line 22: | Line 23: | ||
Line 38: | Line 39: | ||
==== 1.3 Connecting to the command line and file transfer ==== | ==== 1.3 Connecting to the command line and file transfer ==== | ||
Line 132: | Line 133: | ||
- | Then transfer the new file back onto the Venus device. | + | Then transfer the new file back onto the [[venus-os: |
Line 143: | Line 144: | ||
Line 155: | Line 158: | ||
Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. | ||
- | Make sure that the Venus device (fe. CCGX), as well as routers or any other used communications equipment, are __not__ powered by the VE.Bus devices. If they are, you'll lose power and connection as soon as the update is started, resulting in a dead system. | + | Make sure that the [[venus-os: |
Line 284: | Line 287: | ||
Querying devices | Querying devices | ||
+ | # vreg --help | ||
+ | -b,--bin | ||
+ | -g,--get | ||
+ | Get a register. | ||
+ | -n,--nad | ||
+ | -r,--run | ||
+ | Keep running. | ||
+ | -s,--set | ||
+ | COMMON OPTIONS: | ||
+ | -c, --canbus | ||
+ | -d, --dump | ||
+ | -h, --help | ||
+ | Print this help. | ||
+ | --log-before < | ||
+ | --log-after < | ||
+ | Like -log-before, | ||
+ | --silent | ||
+ | -v --verbose | ||
+ | Victron Energy B.V. | ||
+ | Example of switching a solar charger off, and then on | ||
+ | OFF: (vreg 0x0200, value 4) | ||
+ | ccgx:~# vreg -n 0x45 -s 0x0200 un8:0x04 | ||
+ | # NAD 0x45, reg=0x200 | ||
+ | 0x04 0x00 0x00 0x00 | ||
+ | ON: (vreg 0x0200, value 1) | ||
+ | root@ccgx: | ||
+ | 0x01 0x00 0x00 0x00 | ||
+ | root@ccgx: | ||
+ | Gets can be broadcasted, | ||
+ | vreg -c socketcan: | ||
+ | root@einstein: | ||
+ | # reminder, there are no error indications when broadcasting! | ||
+ | # NAD 0x24, reg=0x200 | ||
+ | # NAD 0x25, reg=0x200 | ||
+ | # NAD 0x26, reg=0x200 | ||
+ | and so forth | ||
- | First make sure to stop the serial starter: | + | ==== 5.1 See connected devices ==== |
- | + | # svstat /service/* | grep vedirect | |
- | List all services running: | + | /service/vedirect-interface.ttyO2: |
- | svstat /service/* | + | ==== 5.2 Firmware update ==== |
- | Look for the product you and to update, and stop that service as well: | + | First stop the driver: |
- | | + | /opt/victronenergy/ |
Then update the product: | Then update the product: | ||
Line 322: | Line 409: | ||
- | and when done, start the service and the serial-starter | + | and when done, release |
+ | See here: https:// | ||
- | svc -u / | + | That API allows to read and write VREGs. See MPPT, BMV and other HEX Protocol documents on our white paper section on the website for more information. Once you understood it all; its possible to reset a BMV too 100% with a one liner from the command line, ie " |
- | svc -u / | + | |
