open_source:ccgx:commandline
open_source:ccgx:commandline [2018-02-14 11:12] – [2.3 Venus v1.74 and before] mvader | open_source:ccgx:commandline [2021-03-06 14:38] – [8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub)] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a Venus device, for example the Color Control GX, via the command line, ie ssh. | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
- | Note regarding support: this document is made available for convenience only. There is no guaranteed support | + | For more software developer oriented command line tips & tricks, see [[https://github.com/ |
+ | ==== 1.1 No support warning ==== | ||
- | ==== 1.1 Use a normal tool instead of the command line ==== | + | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; |
+ | In case of questions, you can use the [[https:// | ||
+ | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
+ | ==== 1.2 Use a normal tool instead of the command line ==== | ||
It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | ||
Line 17: | Line 23: | ||
Line 33: | Line 39: | ||
- | ==== 1.2 Connecting to the command line and file transfer ==== | + | ==== 1.3 Connecting to the command line and file transfer ==== |
See the [[ccgx: | See the [[ccgx: | ||
Line 127: | Line 133: | ||
- | Then transfer the new file back onto the Venus device. | + | Then transfer the new file back onto the [[venus-os: |
Line 138: | Line 144: | ||
Line 148: | Line 156: | ||
Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | ||
- | Make sure that the Venus device (fe. CCGX), as well as routers or any other used communications equipment, are __not__ powered by the VE.Bus devices. If they are, you'll lose power and connection as soon as the update is started, resulting in a dead system. | + | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. |
+ | Make sure that the [[venus-os: | ||
Line 278: | Line 288: | ||
+ | # vreg --help | ||
+ | -b,--bin | ||
+ | -g,--get | ||
+ | Get a register. | ||
+ | -n,--nad | ||
+ | -r,--run | ||
+ | Keep running. | ||
+ | -s,--set | ||
+ | COMMON OPTIONS: | ||
+ | -c, --canbus | ||
+ | -d, --dump | ||
+ | -h, --help | ||
+ | Print this help. | ||
+ | --log-before < | ||
+ | --log-after < | ||
+ | Like -log-before, | ||
+ | --silent | ||
+ | -v --verbose | ||
+ | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
- | First make sure to stop the serial starter: | + | ==== 5.1 See connected devices ==== |
- | + | # svstat /service/* | grep vedirect | |
- | List all services running: | + | /service/vedirect-interface.ttyO2: |
- | svstat /service/* | + | ==== 5.2 Firmware update ==== |
- | Look for the product you and to update, and stop that service as well: | + | First stop the driver: |
- | | + | /opt/victronenergy/ |
Then update the product: | Then update the product: | ||
Line 315: | Line 404: | ||
- | and when done, start the service and the serial-starter | + | and when done, release |
- | svc -u /service/ | + | |
+ | See here: https:// | ||
Line 336: | Line 431: | ||
- If you want to set a password, go to Settings -> Remote Console -> Enable password check | - If you want to set a password, go to Settings -> Remote Console -> Enable password check | ||
- | ===== 8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub) ===== | ||
- | If you have a CCGX already installed, but VRM two-way communication is not enabled, follow these steps to enable it remotely: | ||
- | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - VE.Configure should now be able to connect to the CCGX | ||
