open_source:ccgx:commandline
open_source:ccgx:commandline [2017-08-18 09:20] – [1. Introduction] mvader | open_source:ccgx:commandline [2021-03-03 10:14] – [4.4 vreg: changing settings from the command line] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a Venus device, for example the Color Control GX, via the command line, ie ssh. | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
- | Note regarding support: this document is made available for convenience only. There is no guaranteed support | + | For more software developer oriented command line tips & tricks, see [[https://github.com/ |
+ | ==== 1.1 No support warning ==== | ||
- | ==== 1.1 Use a normal tool instead of the command line ==== | + | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; |
+ | In case of questions, you can use the [[https:// | ||
+ | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
+ | ==== 1.2 Use a normal tool instead of the command line ==== | ||
It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | ||
Line 17: | Line 23: | ||
Line 33: | Line 39: | ||
- | ==== 1.2 Connecting to the command line and file transfer ==== | + | ==== 1.3 Connecting to the command line and file transfer ==== |
See the [[ccgx: | See the [[ccgx: | ||
Line 47: | Line 53: | ||
Check firmware version: | Check firmware version: | ||
- | root@CCGX: | + | root@CCGX: |
v2.06 | v2.06 | ||
Color Control GX | Color Control GX | ||
Line 59: | Line 65: | ||
==== 2.2 Venus v2.00 and later ==== | ==== 2.2 Venus v2.00 and later ==== | ||
- | Checking for updates and triggering a new update is all done with / | + | Checking for updates and triggering a new update is all done with / |
For an introduction, | For an introduction, | ||
Line 65: | Line 71: | ||
==== 2.3 Venus v1.74 and before ==== | ==== 2.3 Venus v1.74 and before ==== | ||
+ | === Updating to v2.00 and later === | ||
+ | This needs to be done with an sdcard. There is no other way. See instructions here: | ||
+ | https:// | ||
=== Updating Venus version === | === Updating Venus version === | ||
Line 122: | Line 133: | ||
- | Then transfer the new file back onto the Venus device. | + | Then transfer the new file back onto the [[venus-os: |
Line 133: | Line 144: | ||
Line 143: | Line 156: | ||
Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | ||
- | Make sure that the Venus device (fe. CCGX), | + | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. |
+ | Make sure that the [[venus-os: | ||
Line 272: | Line 287: | ||
Querying devices | Querying devices | ||
+ | # vreg --help | ||
+ | -b,--bin | ||
+ | -g,--get | ||
+ | Get a register. | ||
+ | -n,--nad | ||
+ | -r,--run | ||
+ | Keep running. | ||
+ | -s,--set | ||
+ | COMMON OPTIONS: | ||
+ | -c, --canbus | ||
+ | -d, --dump | ||
+ | -h, --help | ||
+ | Print this help. | ||
+ | --log-before < | ||
+ | --log-after < | ||
+ | Like -log-before, | ||
+ | --silent | ||
+ | -v --verbose | ||
+ | Victron Energy B.V. | ||
+ | Example of switching a solar charger off, and then on | ||
+ | OFF: (vreg 0x0200, value 4) | ||
+ | ccgx:~# vreg -n 0x45 -s 0x0200 un8:0x04 | ||
+ | # NAD 0x45, reg=0x200 | ||
+ | 0x04 0x00 0x00 0x00 | ||
+ | ON: (vreg 0x0200, value 1) | ||
+ | root@ccgx: | ||
+ | 0x01 0x00 0x00 0x00 | ||
+ | root@ccgx: | ||
+ | Gets can be broadcasted, | ||
+ | vreg -c socketcan: | ||
+ | root@einstein: | ||
+ | # reminder, there are no error indications when broadcasting! | ||
+ | # NAD 0x24, reg=0x200 | ||
+ | # NAD 0x25, reg=0x200 | ||
+ | # NAD 0x26, reg=0x200 | ||
+ | and so forth | ||
- | First make sure to stop the serial starter: | + | ==== 5.1 See connected devices ==== |
- | + | # svstat /service/* | grep vedirect | |
- | List all services running: | + | /service/vedirect-interface.ttyO2: |
- | svstat /service/* | + | ==== 5.2 Firmware update ==== |
- | Look for the product you and to update, and stop that service as well: | + | First stop the driver: |
- | | + | /opt/victronenergy/ |
Then update the product: | Then update the product: | ||
Line 310: | Line 409: | ||
- | and when done, start the service and the serial-starter | + | and when done, release |
- | svc -u /service/ | + | |
+ | See here: https:// | ||
Line 337: | Line 442: | ||
- VE.Configure should now be able to connect to the CCGX | - VE.Configure should now be able to connect to the CCGX | ||
