open_source:ccgx:commandline
open_source:ccgx:commandline [2017-07-11 13:15] – [2.2 Venus v2.00 and later] mvader | open_source:ccgx:commandline [2022-09-15 10:27] – [4.3 Restarting a VE.Can device] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a Venus device, for example the Color Control GX. | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
- | Note regarding support: below documentation are made available to be convenient only. There is no guaranteed support | + | For more software developer oriented command line tips & tricks, see [[https://github.com/ |
+ | ==== 1.1 No support warning ==== | ||
- | ==== 1.1 Use a normal tool instead of the command line ==== | + | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; |
+ | In case of questions, you can use the [[https:// | ||
+ | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
+ | ==== 1.2 Use a normal tool instead of the command line ==== | ||
It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | ||
Line 17: | Line 23: | ||
Line 33: | Line 39: | ||
- | ==== 1.2 Connecting to the command line and file transfer ==== | + | ==== 1.3 Connecting to the command line and file transfer ==== |
See the [[ccgx: | See the [[ccgx: | ||
Line 47: | Line 53: | ||
Check firmware version: | Check firmware version: | ||
- | root@CCGX: | + | root@CCGX: |
v2.06 | v2.06 | ||
Color Control GX | Color Control GX | ||
Line 55: | Line 61: | ||
Then to update, this depends on which version you are running. Up until v1.74 we were using opkg package updates. And then we switched to image based updates, and jumped with the version number to v2.00. | Then to update, this depends on which version you are running. Up until v1.74 we were using opkg package updates. And then we switched to image based updates, and jumped with the version number to v2.00. | ||
- | See [[ccgx: | + | See [[ccgx: |
==== 2.2 Venus v2.00 and later ==== | ==== 2.2 Venus v2.00 and later ==== | ||
- | Checking for updates and triggering a new update is all done with / | + | Checking for updates and triggering a new update is all done with / |
For an introduction, | For an introduction, | ||
Line 65: | Line 71: | ||
==== 2.3 Venus v1.74 and before ==== | ==== 2.3 Venus v1.74 and before ==== | ||
+ | === Updating to v2.00 and later === | ||
+ | This needs to be done with an sdcard. There is no other way. See instructions here: | ||
+ | https:// | ||
=== Updating Venus version === | === Updating Venus version === | ||
- | To trigger an update check, run | + | To trigger an update check, run: |
Line 73: | Line 84: | ||
- | If there are new updates found, and if the GUI is running and automatic updates are enabled, the GUI will automatically initiate an update followed by a reboot. Otherwise, trigger the installation yourself with | + | If there are new updates found, and if the GUI is running and automatic updates are enabled, the GUI will automatically initiate an update followed by a reboot. Otherwise, trigger the installation yourself with: |
Line 122: | Line 133: | ||
- | Then transfer the new file back onto the Venus device. | + | Then transfer the new file back onto the [[venus-os: |
Line 133: | Line 144: | ||
Line 143: | Line 156: | ||
Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | ||
- | Make sure that the Venus device (fe. CCGX), | + | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. |
+ | Make sure that the [[venus-os: | ||
Line 268: | Line 283: | ||
UDF is ready to accept update. | UDF is ready to accept update. | ||
Udf enabled, update can begin. | Udf enabled, update can begin. | ||
+ | ->> NOTE THAT IT CAN ALSO HAPPEN THAT THE -u COMMAND RETURNS AN ERROR. WHICH IS NORMAL. YOU | ||
+ | CAN VERIFY IF IT WAS SUCCESSFULL BY RUNNING JUST vup. IT WILL SHOW ALL DEVICES AND INDICATE | ||
+ | IF THEY ARE IN BOOTLOADER MODE (-u WAS SUCCESSFULL) OR NOT | ||
root@ccgx: | root@ccgx: | ||
Line 273: | Line 292: | ||
+ | # vreg --help | ||
+ | -b,--bin | ||
+ | -g,--get | ||
+ | Get a register. | ||
+ | -n,--nad | ||
+ | -r,--run | ||
+ | Keep running. | ||
+ | -s,--set | ||
+ | COMMON OPTIONS: | ||
+ | -c, --canbus | ||
+ | -d, --dump | ||
+ | -h, --help | ||
+ | Print this help. | ||
+ | --log-before < | ||
+ | --log-after < | ||
+ | Like -log-before, | ||
+ | --silent | ||
+ | -v --verbose | ||
+ | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
- | First make sure to stop the serial starter: | + | ==== 5.1 See connected devices ==== |
- | + | # svstat /service/* | grep vedirect | |
- | List all services running: | + | /service/vedirect-interface.ttyO2: |
- | svstat /service/* | + | ==== 5.2 Firmware update ==== |
- | Look for the product you and to update, and stop that service as well: | + | First stop the driver: |
- | | + | /opt/victronenergy/ |
Then update the product: | Then update the product: | ||
Line 310: | Line 408: | ||
- | and when done, start the service and the serial-starter | + | and when done, release |
- | svc -u /service/ | + | |
+ | See here: https:// | ||
Line 324: | Line 428: | ||
- SSH into CCGX (make a root password by following instructions [[ccgx: | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - < | + | - Enable Remote Console on LAN: < |
- | - < | + | - Create the password file. Empty file means no password: |
- Reboot CCGX via SSH: < | - Reboot CCGX via SSH: < | ||
- Now you should be able to access Remote Console feature from VRM | - Now you should be able to access Remote Console feature from VRM | ||
- If you want to set a password, go to Settings -> Remote Console -> Enable password check | - If you want to set a password, go to Settings -> Remote Console -> Enable password check | ||
- | ===== 8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub) ===== | ||
- | If you have a CCGX already installed, but VRM two-way communication is not enabled, follow these steps to enable it remotely: | ||
- | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - VE.Configure should now be able to connect to the CCGX | ||
