open_source:ccgx:commandline
open_source:ccgx:commandline [2017-06-20 14:34] – [4.2 Restoring VE.Can products to their defaults] mvader | open_source:ccgx:commandline [2022-09-15 10:27] – [4.3 Restarting a VE.Can device] mvader | ||
- | This page explains how to change settings and/or update firmware for various Victron products which are connected to a Venus device, for example the Color Control GX. | + | This page explains how to change settings and/or update firmware for various Victron products which are connected to a [[venus-os: |
- | Note regarding support: below documentation are made available to be convenient only. There is no guaranteed support | + | For more software developer oriented command line tips & tricks, see [[https://github.com/ |
+ | ==== 1.1 No support warning ==== | ||
- | ==== 1.1 Use a normal tool instead of the command line ==== | + | Note regarding support: this document is made available for convenience only. There is no support on this type of using our products. Using the command line is outside normal use; |
+ | In case of questions, you can use the [[https:// | ||
+ | Our support staff on all official channels, Disqus and elsewhere, does not know how these tools can be used. | ||
+ | ==== 1.2 Use a normal tool instead of the command line ==== | ||
It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | It is not at all necessary to use below command line instructions. We have far easier to use normal computer applications available: | ||
Line 17: | Line 23: | ||
Line 33: | Line 39: | ||
- | ==== 1.2 Connecting to the command line and file transfer ==== | + | ==== 1.3 Connecting to the command line and file transfer ==== |
See the [[ccgx: | See the [[ccgx: | ||
Line 45: | Line 51: | ||
===== 2. Venus software updates ===== | ===== 2. Venus software updates ===== | ||
- | ==== 2.1 Checking current | + | Check firmware |
- | root@CCGX: | + | root@CCGX: |
v2.06 | v2.06 | ||
Color Control GX | Color Control GX | ||
Line 53: | Line 59: | ||
- | ==== 2.2 Updating Venus version | + | Then to update, this depends on which version |
- | To trigger an update check, run | + | See [[ccgx: |
+ | ==== 2.2 Venus v2.00 and later ==== | ||
+ | Checking for updates and triggering a new update is all done with / | ||
+ | For an introduction, | ||
+ | ==== 2.3 Venus v1.74 and before ==== | ||
+ | === Updating to v2.00 and later === | ||
+ | This needs to be done with an sdcard. There is no other way. See instructions here: | ||
+ | https:// | ||
+ | === Updating Venus version === | ||
+ | To trigger an update check, run: | ||
Line 61: | Line 84: | ||
- | If there are new updates found, and if the GUI is running and automatic updates are enabled, the GUI will automatically initiate an update followed by a reboot. Otherwise, trigger the installation yourself with | + | If there are new updates found, and if the GUI is running and automatic updates are enabled, the GUI will automatically initiate an update followed by a reboot. Otherwise, trigger the installation yourself with: |
Line 69: | Line 92: | ||
To change the Update-to setting, use set-feed.sh. | To change the Update-to setting, use set-feed.sh. | ||
- | ==== 2.3 Automatic | + | === Automatic |
To check if the device is configured to automatically update, query / | To check if the device is configured to automatically update, query / | ||
Line 110: | Line 133: | ||
- | Then transfer the new file back onto the Venus device. | + | Then transfer the new file back onto the [[venus-os: |
Line 121: | Line 144: | ||
Line 131: | Line 156: | ||
Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | Updating other VE.Bus devices, such as the VE.Bus BMS and Digital Multi Control panels is not possible with vbdup. | ||
- | Make sure that the Venus device (fe. CCGX), | + | Updating a MultiGrid and also a MultiPlus-II is not (yet) possible with vbdup. |
+ | Make sure that the [[venus-os: | ||
Line 256: | Line 283: | ||
UDF is ready to accept update. | UDF is ready to accept update. | ||
Udf enabled, update can begin. | Udf enabled, update can begin. | ||
+ | ->> NOTE THAT IT CAN ALSO HAPPEN THAT THE -u COMMAND RETURNS AN ERROR. WHICH IS NORMAL. YOU | ||
+ | CAN VERIFY IF IT WAS SUCCESSFULL BY RUNNING JUST vup. IT WILL SHOW ALL DEVICES AND INDICATE | ||
+ | IF THEY ARE IN BOOTLOADER MODE (-u WAS SUCCESSFULL) OR NOT | ||
root@ccgx: | root@ccgx: | ||
Line 261: | Line 292: | ||
+ | # vreg --help | ||
+ | -b,--bin | ||
+ | -g,--get | ||
+ | Get a register. | ||
+ | -n,--nad | ||
+ | -r,--run | ||
+ | Keep running. | ||
+ | -s,--set | ||
+ | COMMON OPTIONS: | ||
+ | -c, --canbus | ||
+ | -d, --dump | ||
+ | -h, --help | ||
+ | Print this help. | ||
+ | --log-before < | ||
+ | --log-after < | ||
+ | Like -log-before, | ||
+ | --silent | ||
+ | -v --verbose | ||
+ | Victron Energy B.V. | ||
+ | vreg -c socketcan: | ||
- | First make sure to stop the serial starter: | + | ==== 5.1 See connected devices ==== |
- | + | # svstat /service/* | grep vedirect | |
- | List all services running: | + | /service/vedirect-interface.ttyO2: |
- | svstat /service/* | + | ==== 5.2 Firmware update ==== |
- | Look for the product you and to update, and stop that service as well: | + | First stop the driver: |
- | | + | /opt/victronenergy/ |
Then update the product: | Then update the product: | ||
Line 298: | Line 408: | ||
- | and when done, start the service and the serial-starter | + | and when done, release |
- | svc -u /service/ | + | |
+ | See here: https:// | ||
Line 312: | Line 428: | ||
- SSH into CCGX (make a root password by following instructions [[ccgx: | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - < | + | - Enable Remote Console on LAN: < |
- | - < | + | - Create the password file. Empty file means no password: |
- Reboot CCGX via SSH: < | - Reboot CCGX via SSH: < | ||
- Now you should be able to access Remote Console feature from VRM | - Now you should be able to access Remote Console feature from VRM | ||
- If you want to set a password, go to Settings -> Remote Console -> Enable password check | - If you want to set a password, go to Settings -> Remote Console -> Enable password check | ||
- | ===== 8. Enabling VRM two-way communication (Remote VEConfigure aka vrmpubnub) ===== | ||
- | If you have a CCGX already installed, but VRM two-way communication is not enabled, follow these steps to enable it remotely: | ||
- | - SSH into CCGX (make a root password by following instructions [[ccgx: | ||
- | - VE.Configure should now be able to connect to the CCGX | ||
