hv_battery_compatibility:start
HV Battery Compatibility - Multi HS19
The Victron HS19 high voltage inverter/charger only works with supported and compatible high voltage batteries.
These batteries are strongly recommended to be connected via “BMS-Can” (CANBus) to a GX device. The HS19 supports direct battery connection without a GX device, see product manual further details.
Victron provides the following support documentation to assist qualified system designers and installers to select suitable batteries for their application.
Click the brand name for brand-specific information and manufacturer links. This information should always be verified with the battery manufacturer.
Batteries compatible with the Victron HS19
| Brand | Model / series | Usable voltage range with HS19 (V DC) | Modules per stack | Capacity (kWh) |
| Cegasa | E/Scal 6 | 676 - 940 | 13 - 15 | 75 - 86 |
| Freedomwon | LiTE Commercial 300/240 HV+ | 655 - 817 | Pre-built | 300 |
| Hubble | HV100 | 717 - 891 | 8 | 82 |
| LBSA | HV range (Rhino IntelliFlex HV) | 660 - 927 | 10 - 11 | 80 - 88 |
| MG | RS series (RS 230) | 672 - 876 | 14 - 15 | 165 - 177 |
| Pylontech | Force-H3 | 650 - 920 | 7 - 8 | 36 - 41 |
| Pytes | HV48100 | 665 - 870 | 14 - 15 | 70 - 75 |
| Pytes | HV48300 MAX | 665 - 986 | 14 - 17 | 224 - 272 |
| ZYC | SIMPO Pro E | 673 - 958 | 11 | 127 |
| ZYC | SIMPO Pro S | 650 - 934 | 16 | 82 |
hv_battery_compatibility/start.1789698512.txt.gz · Last modified: by guy_stewart
Add this page to your book
Manage book (
Help
