hv_battery_compatibility:lbsa
LBSA HV (Rhino IntelliFlex HV)
Use with the HS19 (650 - 1000 V DC)
  • Modules per rack: 10 - 11 (the product allows 3 - 11; 9 or fewer sits below the HS19 range)
  • Usable voltage range: 660 - 927 V
  • Capacity: 80 - 88 kWh per rack
Full product specifications (unverified, from manufacturer pages)
  • Module: 76.8 V nominal (24S LiFePO4), 104 Ah / 7.98 kWh
  • 100 A continuous per rack (200 A for 60 s); up to 60 racks parallel
Setup guide
Contact battery manufacturer for setup instructions.
hv_battery_compatibility/lbsa.txt · Last modified: by guy_stewart
