hv_battery_compatibility:mg
MG RS Series
Use with the HS19 (650 - 1000 V DC)
  • Modules per string: 14 - 15
  • Usable voltage range: 672 - 876 V
  • Capacity: 165 - 177 kWh per string
Product specifications
  • Module RS 230: 51.2 V nominal (16S1P LiFePO4), 230 Ah / 11.8 kWh, liquid thermal management
  • Up to 32 modules parallel
  • 230 A continuous, 345 A max discharge
  • Requires external MG Master HV BMS for HV strings
Setup guide
Contact battery manufacturer for setup instructions.
hv_battery_compatibility/mg.txt · Last modified: by guy_stewart
