hv_battery_compatibility:start
HV Battery Compatibility - Multi HS19
The Victron HS19 high voltage inverter/charger only works with supported and compatible high voltage batteries.
These batteries are strongly recommended to be connected via “BMS-Can” (CANBus) to a GX device. The HS19 supports direct battery connection without a GX device, see product manual further details.
Victron provides the following support documentation to assist qualified system designers and installers to select suitable batteries for their application.
Click the brand name for brand-specific information and manufacturer links. This information should always be verified with the battery manufacturer.
Batteries compatible with the Victron HS19
Brand Model / series Usable voltage range with HS19 (V DC) Modules per stack Capacity (kWh)
Cegasa E/Scal 6 676 - 940 13 - 15 75 - 86
Freedomwon LiTE Commercial 300/240 HV+ 655 - 817 Pre-built 300
Hubble HV100 717 - 891 8 82
LBSA HV range (Rhino IntelliFlex HV) 660 - 927 10 - 11 80 - 88
MG RS series (RS 230) 672 - 876 14 - 15 165 - 177
Pylontech Force-H3 650 - 920 7 - 8 36
ZYC SIMPO Pro E 673 - 958 11 127
ZYC SIMPO Pro S 650 - 934 16 82
hv_battery_compatibility/start.1782213592.txt.gz · Last modified: by guy_stewart
