ccgx:pump_start_stop
ccgx:pump_start_stop [2016-08-08 15:38] – Page moved from drafts:pump_start_stop to ccgx:pump_start_stop mvader | ccgx:pump_start_stop [2016-08-08 16:25] – [Mobile/automotive overview] mvader | ||
Line 7: | Line 7: | ||
With this functionality you can open or close the relay based on a tank level. | With this functionality you can open or close the relay based on a tank level. | ||
- | ==== Mobile/ | + | ==== Marine & Mobile/ |
On this overview you can easily see all the attached tank sensors levels and control a pump. It is also posible to change Multi/ | On this overview you can easily see all the attached tank sensors levels and control a pump. It is also posible to change Multi/ | ||
+ | To enable this overview, go to Settings -> Display & Language | ||
==== Enable pump start/stop ==== | ==== Enable pump start/stop ==== |
ccgx/pump_start_stop.txt · Last modified: 2019-01-22 10:42 by 127.0.0.1
