ccgx:pump_start_stop
Pump auto start/stop with Color Control GX
Introduction
The CCGX has a relay - switch - which can automatically start a pump. The switch is triggered by 'tank level' data, received from a tank-sender. The level at which the switch is automatically tripped is user-definable.
Boat & Motorhome overview
An additional Overview page is available which shows at-a-glance status information from all tanks connected to the CCGX. To enable the tank overview page from the main menu go to: Settings → Display and language → Show boat and motorhome overview. You will now find that 'Mobile' has been added to CCGX 'homepage showing: 'Overview' and 'Tiles'.
It is also posible to change Multi/Quattro AC current limit and mode when those functions are available.
Enable pump start/stop
To enable the pump start/stop functionality go to Settings →Relay; and set the function to “Tank pump”.
Configuration
Once enabled the tank pump configuration page will be found at: Main Menu →Settings →Tank pump.
Mode
  • Auto: Start and stop the pump based on level settings
  • On: Pump always on
  • Off: Pump always off
Tank sensor
Select which sensor will be monitored to start/stop the pump when the “Auto” mode is enabled.
Pump auto-start levels
Start level: When the tank level reaches this value the pump will be started.
Stop level: When the tank level reaches this value the pump will be stopped.
ccgx/pump_start_stop.txt · Last modified: 2019-01-22 10:42 by 127.0.0.1
