ccgx:modbustcp_faq
ccgx:modbustcp_faq [2020-01-06 12:48] – [6. Error codes and trouble shooting] mvader | ccgx:modbustcp_faq [2023-10-31 10:32] (current) – jpasop | ||
- | ====== GX ModbusTCP | + | ====== GX Modbus-TCP |
- | Besides reading this GX ModbusTCP | + | Besides reading this GX Modbus-TCP |
- | By default, | + | By default, |
==== 2. Addressing, Unit-ID and Registers ==== | ==== 2. Addressing, Unit-ID and Registers ==== | ||
=== 2.1 Definitions === | === 2.1 Definitions === | ||
- | The ModbusTCP | + | The Modbus-TCP |
- | * The **Unit-ID** is the device-selector: | + | * The **Unit-ID** is the device-selector: |
* The **Register Address** then determines the parameter to read or write: ie. voltage, or current, and so forth. | * The **Register Address** then determines the parameter to read or write: ie. voltage, or current, and so forth. | ||
Line 28: | Line 28: | ||
For the overall system data, look for com.victronenergy.system in the excel sheet, and use Unit-ID 100. | For the overall system data, look for com.victronenergy.system in the excel sheet, and use Unit-ID 100. | ||
- | Note that both Unit-ID 0 and Unit-ID 100 map to the same internal address. We recommend to use ID 100, since many ModbusTCP | + | Note that both Unit-ID 0 and Unit-ID 100 map to the same internal address. We recommend to use ID 100, since many Modbus-TCP |
=== 2.3 Register addresses === | === 2.3 Register addresses === | ||
Line 57: | Line 57: | ||
(1): These are the auxiliary temperature sensors built-in to our GX devices, such as the Venus GX. For details, see [[venus-os: | (1): These are the auxiliary temperature sensors built-in to our GX devices, such as the Venus GX. For details, see [[venus-os: | ||
- | ==== 3. Supported | + | ==== 3. Supported |
Line 69: | Line 69: | ||
==== 5. Mapping example ==== | ==== 5. Mapping example ==== | ||
The purpose of this example is to show how to interpret the information in the worksheets of the | The purpose of this example is to show how to interpret the information in the worksheets of the | ||
- | excel sheet containing the modbustcp | + | excel sheet containing the Modbus-TCP |
- | To request the input voltage of a Multi or Quattro, connected to the VE.Bus sockets on the CCGX, use the following settings: Unit-ID 246, and set the data address of the first request register to 3. | + | To request the input voltage of a Multi or Quattro, connected to the VE.Bus sockets on the GX device, use the following settings: Unit-ID 246, and set the data address of the first request register to 3. |
==== 6. Error codes and trouble shooting ==== | ==== 6. Error codes and trouble shooting ==== | ||
Line 83: | Line 83: | ||
Besides double checking the mapping, there are two ways to see where the error lies. One is to check the last error as shown in the GX Device menus. And secondly you can look at the error code as is visible on (most but not all) PLCs. See the two sections below for details. | Besides double checking the mapping, there are two ways to see where the error lies. One is to check the last error as shown in the GX Device menus. And secondly you can look at the error code as is visible on (most but not all) PLCs. See the two sections below for details. | ||
- | === 6.2 Looking up the last ModbusTCP | + | === 6.2 Looking up the last Modbus-TCP |
- | To see why a certain register is not available, use the Settings -> Services -> ModbusTCP | + | To see why a certain register is not available, use the Settings -> Services -> Modbus-TCP |
- | TODO ADD PICTURE | + | {{ : |
=== 6.3 Error codes === | === 6.3 Error codes === | ||
Line 95: | Line 95: | ||
^Code^Name^Description^ | ^Code^Name^Description^ | ||
|0x01|IllegalFunction|The requested function is not supported.| | |0x01|IllegalFunction|The requested function is not supported.| | ||
- | |0x02|IllegalDataAddress|The Unit-ID is available, but one or more of the requested register(s) does not exist.| | + | |0x02|IllegalDataAddress|The |
|0x03|IllegalDataValue|The requested quantity of registers is invalid. See the modbus specs, http:// | |0x03|IllegalDataValue|The requested quantity of registers is invalid. See the modbus specs, http:// | ||
- | |0x0A|GatewayPathUnavailable|Unit-ID is defined in the mapping list, but there is no device found on the mapped port. Double check the Unit-ID mapping list in the excel sheet, and make sure that the device is properly connected to the CCGX, switched on, and that its data is available on the CCGX display.| | + | |0x0A|GatewayPathUnavailable|The requested |
|0x0B|GatewayTargetDeviceFailedToRespond|Requested Unit-ID not found in the mapping list. Double check the Unit-ID mapping list in the excel sheet.| | |0x0B|GatewayTargetDeviceFailedToRespond|Requested Unit-ID not found in the mapping list. Double check the Unit-ID mapping list in the excel sheet.| | ||
Line 103: | Line 103: | ||
==== 7. Support ==== | ==== 7. Support ==== | ||
- | The recommended method for report | + | The recommended method for support |
Direct company support is only offered on a limited basis. For such support, contact our Victron representative. | Direct company support is only offered on a limited basis. For such support, contact our Victron representative. | ||
Line 109: | Line 109: | ||
==== 8. FAQ ==== | ==== 8. FAQ ==== | ||
- | === Q1: Which products can be interfaced via Modbus TCP? === | + | === Q1: Which products can be interfaced via Modbus-TCP? === |
All products that can be connected to the [[https:// | All products that can be connected to the [[https:// | ||
Line 124: | Line 124: | ||
=== Q5: In a parallel or three-phase system, how can I address a single unit? === | === Q5: In a parallel or three-phase system, how can I address a single unit? === | ||
- | You cannot interface with them individually if they are configured for parallel-working; | + | You cannot interface with them individually if they are configured for parallel-working; |
=== Q6: Will unit-id' | === Q6: Will unit-id' | ||
Line 133: | Line 133: | ||
- | If all unit-id' | + | If all unit-id' |
Follow these steps: | Follow these steps: | ||
Line 139: | Line 139: | ||
- Login with SSH (use for example Putty in Windows - or simply type //ssh root@[ip address here]// on a Linux or Mac terminal console. | - Login with SSH (use for example Putty in Windows - or simply type //ssh root@[ip address here]// on a Linux or Mac terminal console. | ||
- List the latest log file:< | - List the latest log file:< | ||
- | cat / | + | cat /var/ |
Line 148: | Line 148: | ||
2016-01-08 16: | 2016-01-08 16: | ||
- | In most cases the problem will be found in either the unit's id address; or the register addresses. Double check the numbers shown in the output with the numbers as used in your modbustcp | + | In most cases the problem will be found in either the unit's id address; or the register addresses. Double check the numbers shown in the output with the numbers as used in your Modbus-TCP |
- | === Q8: Does Modbus TCP support ESS? === | + | === Q8: Does Modbus-TCP support ESS? === |
Yes. See the [[https:// | Yes. See the [[https:// | ||
