ccgx:modbustcp_faq
ccgx:modbustcp_faq [2017-04-20 17:41] – [Introduction] mvader | ccgx:modbustcp_faq [2021-03-20 02:59] – guystewart | ||
- | Besides reading this FAQ, make sure to also read the ModbusTCP section in our [[https:// | + | Modbus-TCP is an industry standard protocol, that can be used to interface PLCs or other third party equipment with Victron products. Through the Modbus-TCP interface you can read and write data to the chargers, battery monitors, inverter/chargers and other products connected to the GX device. |
+ | === 2.2 Unit-IDs === | ||
+ | ==== 3. Supported | ||
Line 16: | Line 67: | ||
+ | The purpose of this example is to show how to interpret the information in the worksheets of the | ||
+ | excel sheet containing the Modbus-TCP mapping. This excel sheet is available for download from our website on the [[https:// | ||
+ | To request the input voltage of a Multi or Quattro, connected to the VE.Bus sockets on the GX device, use the following settings: Unit-ID 246, and set the data address of the first request register to 3. | ||
+ | The Modbus-TCP reply will contain 2302. Divide it by 10, as specified in cell E3, and then you have the voltage: 230.2 Volts AC. | ||
+ | ==== 6. Error codes and trouble shooting | ||
+ | === 6.1 The common cause: Unit-ID / Register combination === | ||
+ | In case a certain read or write is not successful, most likely there is an issue in the unitid/ | ||
+ | Besides double checking the mapping, there are two ways to see where the error lies. One is to check the last error as shown in the GX Device menus. And secondly you can look at the error code as is visible on (most but not all) PLCs. See the two sections below for details. | ||
+ | === 6.2 Looking up the last Modbus-TCP Error on the GX Device=== | ||
+ | To see why a certain register is not available, use the Settings -> Services -> Modbus-TCP menu. It shows the last error, and reason for that error. | ||
+ | === 6.3 Error codes === | ||
+ | These error codes are returned by our software to the PLC; and most PLC software tools allow seeing them. | ||
^Code^Name^Description^ | ^Code^Name^Description^ | ||
- | |0x01|IllegalFunction|The requested function is not supported| | + | |0x01|IllegalFunction|The requested function is not supported.| |
- | |0x02|IllegalDataAddress|The | + | |0x02|IllegalDataAddress|The |
- | |0x03|IllegalDataValue|The requested quantity of registers is invalid. See the modbus specs, http:// | + | |0x03|IllegalDataValue|The requested quantity of registers is invalid. See the modbus specs, http:// |
- | |0x0A|GatewayPathUnavailable|Unit | + | |0x0A|GatewayPathUnavailable|The requested |
- | |0x0B|GatewayTargetDeviceFailedToRespond|Requested | + | |0x0B|GatewayTargetDeviceFailedToRespond|Requested |
- | ==== Mapping example ==== | ||
- | The purpose of this example is to show how to interpret the information in the worksheets of the | ||
- | excel sheet containing the modbustcp mapping. This excel sheet is available for download from our website on the [[https:// | ||
- | To request the input voltage of a Multi or Quattro, connected to the VE.Bus sockets on the CCGX, use the following settings: unit-id 246, and set the data address of the first request register to 3. | + | ==== 7. Support ==== |
- | The ModbusTCP reply will contain 2302. Divide it by 10, as specified in cell E3, and then you have the voltage: 230.2 Volts AC. | + | The recommended method for support on Modbus-TCP questions is to use the [[https://community.victronenergy.com/ |
- | ==== Enabling ModbusTCP | + | Direct company support is only offered |
- | ==== What is a unit id and what do I need to set it to? ==== | + | ==== 8. FAQ ==== |
- | The unit id, sometimes called ‘slave address’, specifies what product connected to the CCGX needs to be addressed. See the tab ‘Unit ID mapping’ tab in the Modbus-TCP excel sheet. | + | |
- | ==== Which products can be interfaced via Modbus TCP? ==== | + | === Q1: Which products can be interfaced via Modbus-TCP? === |
All products that can be connected to the [[https:// | All products that can be connected to the [[https:// | ||
- | ==== Can I change a configuration setting in a Multi, for example the absorption voltage? | + | === Q2: Can I change a configuration setting in a Multi - for example: the absorption voltage? === |
No. | No. | ||
- | ==== Can I request multiple registers at the same time? ==== | + | === Q3: Can I request multiple registers at the same time? === |
Yes, you can! Though make sure not to include non existing registers in your query. Querying register 1 to 100 for example will not work, since registers 1 and 2 do not exist. | Yes, you can! Though make sure not to include non existing registers in your query. Querying register 1 to 100 for example will not work, since registers 1 and 2 do not exist. | ||
- | ==== Can I implement more features myself? | + | === Q4: Can I implement more features myself? === |
Yes, you can! We are, slowly, making the Color Control code open source, and the Modbus-TCP sources are already available on https:// | Yes, you can! We are, slowly, making the Color Control code open source, and the Modbus-TCP sources are already available on https:// | ||
- | ==== In a parallel or three phase system, how can I address a single unit? ==== | + | === Q5: In a parallel or three-phase system, how can I address a single unit? === |
- | You cannot interface | + | You cannot interface |
+ | === Q6: Will unit-id' | ||
- | ==== Will unit ids change after a reboot or loss of power? ==== | + | No. |
- | Only for vedirect Devices via USB it can change. But even then our experience is that it only changes in the first reboot. | + | === Q7: Advanced debugging === |
- | Unit ids of products not connected via USB will not change. | ||
- | ==== Advanced debugging ==== | + | If all unit-id' |
- | In case all unit-ids and register addresses have been checked and double checked, and still it doesn' | + | Follow these steps: |
- | + | - [[ccgx: | |
- | Steps: | + | - Login with SSH (use for example Putty in Windows - or simply type //ssh root@[ip address here]// |
- | - Enable SSH | + | |
- | - Login, use for example Putty in windows, | + | |
- List the latest log file:< | - List the latest log file:< | ||
cat / | cat / | ||
Line 79: | Line 148: | ||
2016-01-08 16: | 2016-01-08 16: | ||
- | In most cases there is a problem in either unit ids or the register addresses. Double check the numbers shown in the output with the numbers as used in your modbustcp | + | In most cases the problem |
+ | === Q8: Does Modbus-TCP support ESS? === | ||
+ | Yes. See the [[https:// | ||
- | ==== Does Modbus TCP support Hub-4? ==== | ||
- | Yes. See the [[https:// | ||
- | ==== Disqus ==== | ||
