ccgx:modbustcp_faq
ccgx:modbustcp_faq [2015-07-07 12:33] – mvader | ccgx:modbustcp_faq [2021-03-20 02:59] – guystewart | ||
- | Besides reading this FAQ, make sure to also read the ModbusTCP section in our [[http:// | + | Modbus-TCP is an industry standard protocol, that can be used to interface PLCs or other third party equipment with Victron products. Through the Modbus-TCP interface you can read and write data to the chargers, battery monitors, inverter/chargers and other products connected to the GX device. |
+ | === 2.2 Unit-IDs === | ||
+ | ==== 3. Supported | ||
Line 16: | Line 67: | ||
- | ^Code^Name^Description^ | + | |
- | |0x01|IllegalFunction|The requested function is not supported| | + | |
- | |0x02|IllegalDataAddress|The unid it is available, but one or more of the requested register(s) do not exist| | + | |
- | |0x03|IllegalDataValue|The requested quantity of registers is invalid. See the modbus specs, http:// | + | |
- | |0x0A|GatewayPathUnavailable|Unit id is defined in the mapping list, but the DBus service mapped to this requested unit id does not exist| | + | |
- | |0x0B|GatewayTargetDeviceFailedToRespond|Requested unit id not found in the mapping list, double check the unit id mapping list in the excel sheet| | + | |
- | ==== Mapping example ==== | + | |
The purpose of this example is to show how to interpret the information in the worksheets of the | The purpose of this example is to show how to interpret the information in the worksheets of the | ||
- | excel sheet containing the modbustcp | + | excel sheet containing the Modbus-TCP |
- | To request the input voltage of a Multi or Quattro, connected to the VE.Bus sockets on the CCGX, use the following settings: | + | To request the input voltage of a Multi or Quattro, connected to the VE.Bus sockets on the GX device, use the following settings: |
- | The ModbusTCP | + | The Modbus-TCP |
- | ==== Enabling ModbusTCP on the CCGX ==== | + | ==== 6. Error codes and trouble shooting |
- | ==== Which products can be interfaced via Modbus TCP? ==== | + | === 6.1 The common cause: Unit-ID / Register combination |
- | Check the latest [[http:// | + | |
- | ==== Which parameters can I control via Modbus TCP? ==== | + | In case a certain read or write is not successful, most likely there is an issue in the unitid/ |
- | | com.victronenergy.vebus | + | Besides double checking the mapping, there are two ways to see where the error lies. One is to check the last error as shown in the GX Device menus. And secondly you can look at the error code as is visible on (most but not all) PLCs. See the two sections below for details. |
- | | com.victronenergy.vebus | + | |
- | | com.victronenergy.solarcharger | /Mode | 0=Off; | + | |
- | | com.victronenergy.bms | / | + | |
- | | com.victronenergy.charger | + | |
+ | === 6.2 Looking up the last Modbus-TCP Error on the GX Device=== | ||
- | ==== Can I change | + | To see why a certain register is not available, use the Settings -> Services -> Modbus-TCP menu. It shows the last error, and reason for that error. |
- | No not yet. | + | |
- | ==== Can I request multiple registers at the same time? ==== | + | {{ : |
+ | === 6.3 Error codes === | ||
+ | These error codes are returned by our software to the PLC; and most PLC software tools allow seeing them. | ||
+ | ^Code^Name^Description^ | ||
+ | |0x01|IllegalFunction|The requested function is not supported.| | ||
+ | |0x02|IllegalDataAddress|The requested Unit-ID is available, but one or more of the requested register(s) does not exist.| | ||
+ | |0x03|IllegalDataValue|The requested quantity of registers is invalid. See the modbus specs, http:// | ||
+ | |0x0A|GatewayPathUnavailable|The requested Unit-ID is defined in the mapping list, but there is no device found on the mapped port. Double check the Unit-ID mapping list in the excel sheet, and make sure that the device is properly connected to the GX device, switched on, and that its data is available on the GX device display.| | ||
+ | |0x0B|GatewayTargetDeviceFailedToRespond|Requested Unit-ID not found in the mapping list. Double check the Unit-ID mapping list in the excel sheet.| | ||
+ | ==== 7. Support ==== | ||
+ | The recommended method for support on Modbus-TCP questions is to use the [[https:// | ||
+ | Direct company support is only offered on a limited basis. For such support, contact our Victron representative. | ||
+ | ==== 8. FAQ ==== | ||
+ | === Q1: Which products can be interfaced via Modbus-TCP? === | ||
+ | All products that can be connected to the [[https:// | ||
+ | === Q2: Can I change a configuration setting in a Multi - for example: the absorption voltage? === | ||
+ | No. | ||
+ | === Q3: Can I request multiple registers at the same time? === | ||
Yes, you can! Though make sure not to include non existing registers in your query. Querying register 1 to 100 for example will not work, since registers 1 and 2 do not exist. | Yes, you can! Though make sure not to include non existing registers in your query. Querying register 1 to 100 for example will not work, since registers 1 and 2 do not exist. | ||
- | ==== Can I implement more features myself? | + | === Q4: Can I implement more features myself? === |
Yes, you can! We are, slowly, making the Color Control code open source, and the Modbus-TCP sources are already available on https:// | Yes, you can! We are, slowly, making the Color Control code open source, and the Modbus-TCP sources are already available on https:// | ||
- | ==== In a parallel or three phase system, how can I address a single unit? ==== | + | === Q5: In a parallel or three-phase system, how can I address a single unit? === |
- | You cannot interface to them individually if they are configured to be in parallel or as a three phase system. Note that is also not necessary to address the units individually, | + | |
- | ==== I have two or more different VE.Bus systems connected, how can I address each of them? ==== | + | You cannot interface with them individually if they are configured |
- | If you have, for example, two Multis in parallel, and also a separate Quattro, you have two VE.Bus systems: | + | |
- | Each of them will have a different unit id. The unit id of the system connected to the VE.Bus port on the back of the CCGX will have unit id 246. The unit id of the other one, connected to the VE.Can ports via a //VE.Bus to VE.Can interface//, | + | === Q6: Will unit-id's change after a reboot or loss of power? === |
- | To connect multiple VE.Bus systems connected via VE.Can, you need to have multiple VE.Bus to VE.Can interfaces. To make them addressable, | + | No. |
- | ==== Will unit ids change after a reboot or loss of power? ==== | + | |
- | Only for vedirect Devices via USB it can change. But even then our experience is that it only changes in the first reboot. | + | === Q7: Advanced debugging === |
- | Unit ids of products not connected via USB will not change. | ||
- | ==== After upgrading the CCGX to v1.16 or later, ModbusTCP no longer works? ==== | + | If all unit-id' |
- | After learning from our first ModbusTCP experiences with v1.14, we have changed a few things in v1.16: | + | |
- | * VE-Bus port was 254, is now 246 | + | |
- | * VE.Direct port 1 was 255, is now 247 | + | |
- | * VE.Direct port 2 was 253, is now 245 | + | |
- | Best is to change your PLC program to the new unit ids. If you can’t do that, change unitid2di.csv | + | Follow these steps: |
+ | - [[ccgx: | ||
+ | - Login with SSH (use for example Putty in Windows - or simply type //ssh root@[ip address here]// on a Linux or Mac terminal console. | ||
+ | cat /log/ | ||
- | There are two ways of enabling ModbusTCP: | + | In case of any errors, the output will look like this: |
- | - use the menu and the buttons to find the services menu (last one in the list), and then enable ModbusTCP. | + | |
- | - login via ssh (only available if remote support is enabled), and then execute | + | |
- | | + | 2016-01-08 16: |
+ | 2016-01-08 16: | ||
- | Our apologies for this change, we know how much hassle this can cause. | + | In most cases the problem will be found in either the unit's id address; or the register addresses. Double check the numbers shown in the output with the numbers as used in your Modbus-TCP software or PLC. |
- | ==== Does modebus | + | === Q8: Does Modbus-TCP support |
- | Yes. These registers were created to take control of Hub-4 behavior: | + | |
- | * //Hub4 grid target//. Used by hub4 control loop (register 2700, unit-id 239 (first USB device) to 233 (last USB device), unit Watts). | + | |
- | * Positive: take power from grid. | + | |
- | * Negative: send power to grid. | + | |
- | * Default: 0W. | + | |
- | * //Max charge percentage// | + | |
- | * Min value 0% | + | |
- | * Max value 100% | + | |
- | * If 0% is set, charging will be disabled, otherwise the AC-In target will be adjusted whenever necessary. | + | |
- | * //Max discharge percentage// | + | |
- | See modbustcp excel sheet for scaling and datatypes, available [[http:// | + | |
- | Notes: | + | Yes. See the [[https://www.victronenergy.com/ |
- | * Three/split-phase is not possible yet. | + | |
- | * The update mechanism is slow, which to our opinion is not perfect, but also no problem. | + | |
- | ==== Disqus ==== | ||
