ccgx:fischer_panda
ccgx:fischer_panda [2019-01-22 10:16] – external edit 127.0.0.1 | ccgx:fischer_panda [2019-07-11 08:50] – [Menu] mvader | ||
Line 27: | Line 27: | ||
**:!: Important: Operation of the generator is only possible and allowed when the xControl or the iControl panel is switched on. ** | **:!: Important: Operation of the generator is only possible and allowed when the xControl or the iControl panel is switched on. ** | ||
- | ===== Menu ===== | + | ===== GX Device |
+ | In Settings -> Services, the selected canbus profile must be one that says NMEA2000. (The default). | ||
When all wiring is complete and the setup has been correctly carried-out, | When all wiring is complete and the setup has been correctly carried-out, | ||
ccgx/fischer_panda.txt · Last modified: 2020-09-07 12:29 by mvader
