ccgx:fischer_panda
ccgx:fischer_panda [2017-08-17 14:44] – [Generator start/stop] mbosma | ccgx:fischer_panda [2020-09-07 12:29] (current) – [Maintenance] mvader | ||
- | As of [[https:// | + | Fischer Panda generator can be connected to a GX Device, which makes it possible to monitor & operate the generator |
+ | The generator needs to be connected to the VE.Can port of the GX Device, which requires a Fischer Panda SAE J1939 module. | ||
===== Requirements ===== | ===== Requirements ===== | ||
- | * CCGX or Venus GX | + | * [[venus-os: |
* Fischer Panda generator, xControl or iGenerator | * Fischer Panda generator, xControl or iGenerator | ||
* Fischer Panda SAE J1939 CAN module (part number 0006107) | * Fischer Panda SAE J1939 CAN module (part number 0006107) | ||
* Fischer Panda FP-Bus to VE.Can adapter (part number 0023441) | * Fischer Panda FP-Bus to VE.Can adapter (part number 0023441) | ||
+ | Fischer Panda Firmware requirements: | ||
+ | * iControl (for the iGenerator): | ||
+ | * iControl panel: no minimum requirement | ||
+ | * xControl (for the constant speed generators): | ||
+ | * xContr panel: 4V29 | ||
+ | * Fischer Panda SAE J1939 CAN module: 2V05 | ||
+ | * Fischer Panda three phase module: 4V0b | ||
===== Connecting ===== | ===== Connecting ===== | ||
==== xControl ==== | ==== xControl ==== | ||
The schematic below shows how to connect a Fischer Panda xControl generator. | The schematic below shows how to connect a Fischer Panda xControl generator. | ||
==== iControl ==== | ==== iControl ==== | ||
The schematic below shows how to connect a Fischer Panda iControl generator. | The schematic below shows how to connect a Fischer Panda iControl generator. | ||
+ | **:!: Important: Operation of the generator is only possible and allowed when the xControl or the iControl panel is switched on. ** | ||
+ | ===== GX Device ===== | ||
+ | In Settings -> Services, the selected canbus profile must be one that says NMEA2000. (The default). | ||
+ | When all wiring is complete and the setup has been correctly carried-out, | ||
- | ===== Menu ===== | ||
- | Once all wiring and setup has been correctly done, the Fischer Panda shows up in the device list: | ||
- | Entering | + | Entering the Fischer Panda device on the menu reveals a page like this: |
- | It features an on/off switch, as well as the status and the main AC parameters: voltage, current and power. Temperature, | + | Notice that it features an on/off switch as well as displaying |
- | {{: | + | Engine temperature, |
===== Generator start/stop ===== | ===== Generator start/stop ===== | ||
- | Besides | + | In addition to the manual start/stop and monitoring, there is also an automatic start/ |
See [[ccgx: | See [[ccgx: | ||
+ | ===== Maintenance ===== | ||
+ | Whenever performing maintenance on the generator, be sure to //stop// the generator from the Fischer Panda control panel. This will disable the Fischer Panda autostart feature, and ensures that the generator cannot be remotely started - by a CCGX, for example. | ||
+ | When the maintenance is completed, make sure you enable the autostart feature again. You can do this on the Fischer Panda control panel in the menu '' | ||
+ | ===== MFD App ==== | ||
+ | The Marine MFD HTML5 app (more information [[https:// | ||
+ | ===== Troubleshooting ===== | ||
+ | === I've set the mode of the genset to ' | ||
+ | Make sure the Fischer Panda autostart feature is on, this allows the GX control the remote on/off of the genset. You can find this option on the control panel in the menu '' | ||
+ | If you're manually trying to start the genset, a toast message appears with the text '' | ||
+ | If the generator auto start/stop is enabled, it will show error ''# | ||
ccgx/fischer_panda.txt · Last modified: 2020-09-07 12:29 by mvader
