ccgx:ccgx_wireless_ac_sensor
ccgx:ccgx_wireless_ac_sensor [2016-05-18 14:44] – [Introduction] mvader | ccgx:ccgx_wireless_ac_sensor [2016-06-08 20:27] – [Three phase] mvader | ||
Line 6: | Line 6: | ||
Note that it is not possible to use multiple sensors on the same position (AC-Out, AC-In 1, etcetera) in a system. The CCGX will in such case only show the value of the last-read sensor. | Note that it is not possible to use multiple sensors on the same position (AC-Out, AC-In 1, etcetera) in a system. The CCGX will in such case only show the value of the last-read sensor. | ||
+ | ==== Three phase ==== | ||
+ | For measuring a three phase system, we recommend to use [[https:// | ||
===== Required hardware ===== | ===== Required hardware ===== |
ccgx/ccgx_wireless_ac_sensor.txt · Last modified: 2021-03-20 03:05 by guystewart
