ccgx:ccgx_wireless_ac_sensor
ccgx:ccgx_wireless_ac_sensor [2015-02-18 14:16] – martijncoster | ccgx:ccgx_wireless_ac_sensor [2019-06-02 14:18] – [Wireless AC Sensor manual] mvader | ||
====== Wireless AC Sensor manual ====== | ====== Wireless AC Sensor manual ====== | ||
+ | (discontinued product) | ||
- | The Wireless AC sensors are used to measure and calculate PV Inverter current (A), voltage (V), power (W) and energy (kWh), and show it on a [[http:// | + | The Wireless AC sensors are used to measure and calculate PV Inverter current (A), voltage (V), power (W) and energy (kWh), and show it on a [[https:// |
+ | Note that it is not possible to use multiple sensors on the same position (AC-Out, AC-In 1, etcetera) in a system. The CCGX will in such case only show the value of the last-read sensor. | ||
+ | ==== Three phase ==== | ||
+ | For measuring a three phase system, we recommend to use [[https:// | ||
===== Required hardware ===== | ===== Required hardware ===== | ||
Line 95: | Line 102: | ||
|Relative humidity |0 - 95 |% | | |Relative humidity |0 - 95 |% | | ||
- | ~~DISQUS~~ | ||
+ | ~~DISQUS~~ | ||
ccgx/ccgx_wireless_ac_sensor.txt · Last modified: 2021-03-20 03:05 by guystewart
