ccgx:ccgx_wireless_ac_sensor
ccgx:ccgx_wireless_ac_sensor [2015-01-05 11:40] – mvader | ccgx:ccgx_wireless_ac_sensor [2019-06-02 14:18] – [Wireless AC Sensor manual] mvader | ||
====== Wireless AC Sensor manual ====== | ====== Wireless AC Sensor manual ====== | ||
+ | (discontinued product) | ||
- | The Wireless AC sensors are used to measure and calculate PV Inverter current (A), voltage (V), power (W) and energy (kWh), and show it on a [[http:// | + | The Wireless AC sensors are used to measure and calculate PV Inverter current (A), voltage (V), power (W) and energy (kWh), and show it on a [[https:// |
+ | Note that it is not possible to use multiple sensors on the same position (AC-Out, AC-In 1, etcetera) in a system. The CCGX will in such case only show the value of the last-read sensor. | ||
+ | ==== Three phase ==== | ||
+ | For measuring a three phase system, we recommend to use [[https:// | ||
===== Required hardware ===== | ===== Required hardware ===== | ||
Line 15: | Line 22: | ||
* AC adapter | * AC adapter | ||
Line 24: | Line 31: | ||
- Disconnect the AC power | - Disconnect the AC power | ||
- | - Connect the gateway to the network using the supplied RJ45 cable. | + | - Connect the gateway to the Ethernet/ |
- Connect the AC power adapter or the USB cable from the ColorControl GX to the gateway | - Connect the AC power adapter or the USB cable from the ColorControl GX to the gateway | ||
Line 30: | Line 37: | ||
For each phase, connect the AC sensor according to the schematic below. Neutral on top side. Line on bottom side. Make sure the direction of the current is correct. | For each phase, connect the AC sensor according to the schematic below. Neutral on top side. Line on bottom side. Make sure the direction of the current is correct. | ||
- | + | {{ :ccgx:quby_gateway_schema.jpg? | |
===== Gateway and sensor pairing ===== | ===== Gateway and sensor pairing ===== | ||
Line 96: | Line 102: | ||
|Relative humidity |0 - 95 |% | | |Relative humidity |0 - 95 |% | | ||
- | ~~DISQUS~~ | ||
+ | ~~DISQUS~~ | ||
ccgx/ccgx_wireless_ac_sensor.txt · Last modified: 2021-03-20 03:05 by guystewart
