ccgx:ccgx_wireless_ac_sensor
ccgx:ccgx_wireless_ac_sensor [2014-12-02 08:21] – Page moved from drafts:ccgx:ccgx_wireless_ac_sensor to ccgx:ccgx_wireless_ac_sensor mvader | ccgx:ccgx_wireless_ac_sensor [2019-06-02 14:18] – [Wireless AC Sensor manual] mvader | ||
- | ====== Wireless AC Sensor manual | + | ====== Wireless AC Sensor manual ====== |
+ | (discontinued product) | ||
- | The Wireless AC sensors are used to measure PV Inverter | + | The Wireless AC sensors are used to measure |
- | [mco: Spanning | + | Note that it is not possible to use multiple sensors on the same position |
- | [ add measurement accuracy etc. or at the end of this doc. ] [mco: hebben we deze info. Ik weet alleen rating zoals die op de sticker op de zijkant staat] | + | ==== Three phase ==== |
+ | For measuring a three phase system, we recommend to use [[https://www.victronenergy.com/ | ||
===== Required hardware ===== | ===== Required hardware ===== | ||
Line 19: | Line 22: | ||
* AC adapter | * AC adapter | ||
===== Installation ===== | ===== Installation ===== | ||
Line 28: | Line 31: | ||
- Disconnect the AC power | - Disconnect the AC power | ||
- | - Connect the gateway to the network using the supplied RJ45 cable. | + | - Connect the gateway to the Ethernet/ |
- Connect the AC power adapter or the USB cable from the ColorControl GX to the gateway | - Connect the AC power adapter or the USB cable from the ColorControl GX to the gateway | ||
Line 34: | Line 37: | ||
For each phase, connect the AC sensor according to the schematic below. Neutral on top side. Line on bottom side. Make sure the direction of the current is correct. | For each phase, connect the AC sensor according to the schematic below. Neutral on top side. Line on bottom side. Make sure the direction of the current is correct. | ||
- | + | {{ :ccgx:quby_gateway_schema.jpg? | |
===== Gateway and sensor pairing ===== | ===== Gateway and sensor pairing ===== | ||
Line 87: | Line 89: | ||
=== Specifications === | === Specifications === | ||
- | [mco: hebben we deze specs? heb een voorbeeld tabel gemaakt aan de hand van de Busch jaeger sensor ] | ||
Line 96: | Line 96: | ||
|Maximum Current |25 |A | | |Maximum Current |25 |A | | ||
- | |Measurement precision | + | |Measurement precision | +/- 2% | | |
- | |Voltage | + | |
- | |Current |+/- |% | | + | |
|Ambient temperature |-25 ~ +35 |oC | | |Ambient temperature |-25 ~ +35 |oC | | ||
Line 104: | Line 102: | ||
|Relative humidity |0 - 95 |% | | |Relative humidity |0 - 95 |% | | ||
- | ~~DISQUS~~ | ||
+ | ~~DISQUS~~ | ||
ccgx/ccgx_wireless_ac_sensor.txt · Last modified: 2021-03-20 03:05 by guystewart
