ccgx:ccgx_wireless_ac_sensor
drafts:ccgx:ccgx_wireless_ac_sensor [2014-10-30 09:18] – created mvader | ccgx:ccgx_wireless_ac_sensor [2021-03-20 03:05] (current) – guystewart | ||
====== Wireless AC Sensor manual ====== | ====== Wireless AC Sensor manual ====== | ||
- | DRAFT | + | (discontinued product) |
- | The Wireless AC sensors | + | |
+ | The Wireless AC sensors | ||
+ | Note that it is not possible to use multiple sensors on the same position (AC-Out, AC-In 1, etcetera) in a system. The GX device will in such case only show the value of the last-read sensor. | ||
+ | ==== Three phase ==== | ||
+ | For measuring a three phase system, we recommend to use [[https:// | ||
===== Required hardware ===== | ===== Required hardware ===== | ||
Line 10: | Line 16: | ||
* TIM000100100 - Wireless AC sensor 25A (one for each phase) | * TIM000100100 - Wireless AC sensor 25A (one for each phase) | ||
* TIM000100000 - Wireless Sensor gateway (one for every system) | * TIM000100000 - Wireless Sensor gateway (one for every system) | ||
- | * RJ45 cable 30cm (included with the gateway) | ||
- | * AC adapter (included with the Wireless Sensor gateway) | ||
- | Note that instead of powering the Wireless Sensor gateway with the AC adapter, it is also possible to power it from one of the USB ports in the Color Control | + | Included with the gateway: |
+ | * RJ45 cable 30cm | ||
+ | * AC adapter | ||
- | [ plaatje micro usb ] | ||
===== Installation ===== | ===== Installation ===== | ||
=== Installing the gateway === | === Installing the gateway === | ||
- Disconnect the AC power | - Disconnect the AC power | ||
- | - Connect the gateway to the network using the supplied RJ45 cable. | + | - Connect the gateway to the Ethernet/ |
- | - Connect the AC power adapter to the gateway | + | - Connect the AC power adapter |
=== Installing the sensor(s) === | === Installing the sensor(s) === | ||
- | - Connect the AC sensor according to the schematic below.Neutral on top side. Line on bottom side. Make sure the direction of the current is correct. | ||
- | ===== Configuration ===== | + | For each phase, connect the AC sensor according to the schematic below. Neutral on top side. Line on bottom side. Make sure the direction of the current is correct. |
+ | ===== Gateway and sensor pairing ===== | ||
+ | After powering the sensor for the first time, it needs to be paired with the gateway. The led on the sensor will be blinking red, to indicate that it is not yet paired to a gateway. | ||
+ | If it is not blinking red, but both the green and the red LED are on, it needs to be unpaired first: press and hold the little reset button in the sensor. As soon as you press the button the LED will turn green. Hold the button until the LED starts blinking red. | ||
+ | To let the gateway search for and pair with free sensors, press the button on the gateway for 5 seconds. The led on the gateway will start blinking red. First slow then both leds (gateway and sensor) will start blinking red fast. If sensor is found the led will shortly blink orange. | ||
+ | The discovery will take anywhere between 30 seconds and 12 minutes. The 12 minutes can be because of a software update. | ||
+ | When the update process is completed then the sensor LED will be off, and the gateway LED will be green with short intermittent blips of red. | ||
+ | === Gateway LED === | ||
+ | ^LED ^Meaning | | ||
+ | |Blinking red |Searching for sensors | | ||
+ | |Green with short blips of red |Working OK | | ||
+ | === Sensor LED === | ||
+ | |Blinking red |Not yet paired to a gateway | | ||
+ | |Both green and red on (no blinking) |Cannot find the gateway. Only shows for a few seconds, after that the led will turn off | | ||
+ | |Alternating red/green |Selected in the GX device menu, useful for identification | | ||
+ | |Green on (no blinking) |Gateway found, connecting. This will show only for a few seconds | | ||
+ | |Off |Working OK, connected to the gateway, cannot find gateway or not powered | | ||
+ | ===== Configuration on the GX device ===== | ||
+ | ==== Wireless AC sensor menu ==== | ||
+ | To configure the gateway and sensor go to the Wireless AC sensor menu | ||
+ | Settings → Wireless AC Sensors | ||
+ | If the gateway is connect to the network it will be shown in the list. If one or more AC sensors are connected these will also show in the list. When connected for the first time only the ID number will be shown and no location. This needs to be selected for the sensor to work properly. | ||
+ | Select a sensor to assign a location to it. For example AC-In1_L3. | ||
+ | === Sensor readout === | ||
+ | When all the sensor are configured the measured values can be seen. Go to the Device List and select PV Inverter on AC In1 for example. | ||
+ | === Specifications === | ||
+ | |Rated voltage |230 |V AC | | ||
+ | |Operating Voltage |220-240 |V AC | | ||
+ | |Frequency |50 |HZ | | ||
+ | |Maximum Current |25 |A | | ||
+ | |Measurement precision | +/- 2% | | | ||
+ | |Ambient temperature |-25 ~ +35 |oC | | ||
+ | |Storage temperature |-25 ~ +70 |oC | | ||
+ | |Relative humidity |0 - 95 |% | | ||
ccgx/ccgx_wireless_ac_sensor.txt · Last modified: 2021-03-20 03:05 by guystewart
