battery_compatibility:redflow_zbm
| Next revision | Previous revision | ||
| battery_compatibility:redflow_zbm [2016-06-10 23:14] – created mvader | battery_compatibility:redflow_zbm [2021-03-20 02:50] (current) – guystewart | ||
| Line 1: | Line 1: | ||
| ====== Victron & Redflow ZBM ====== | ====== Victron & Redflow ZBM ====== | ||
| + | http:// | ||
| - | ===== Charge profile ===== | + | ==== Compatible Victron products |
| - | Charger settings: | + | ==== Charge profile ===== |
| - | - Set both absorption | + | |
| - | - disable storage | + | See the information for the Redflow ZCell at https:// |
| - | - disable bulk protection(?? | + | |
| + | ===== GX Device Connect ===== | ||
| + | Redflow ZBM batteries can be directly interfaced to the GX device (Cerbo GX) for monitoring and control (see below). | ||
| + | Alternatively one or more ZBM batteries can be used with the Redflow/ | ||
| + | For the direct-attach option, the GX device has built in support for directly attaching to one or more Redflow ZBM batteries using the built in Modbus connection | ||
| + | - Connect the GX device | ||
| + | - Monitoring the battery: battery voltage, current, state of charge, temperature and many more ZBM specific alarms and flags. | ||
| + | - Control the battery: set it to run mode, initiate a maintenance cycle, clear the alarms and more. | ||
| + | - Configure the battery: the GX device will automatically assign a unique Modbus address to each battery. Just make sure to connect them, slowly, one by one. After connecting one, wait for it to show up on the GX device, and then connect the next one. Additionally, | ||
| + | ===== DISQUS ===== | ||
| + | ~~DISQUS~~ | ||
| - | ===== Color Control GX ===== | ||
battery_compatibility/redflow_zbm.1465593279.txt.gz · Last modified: by mvader
