battery_compatibility:redflow_zbm
Victron & Redflow ZBM
Charge profile
- Charge voltage 57.6V (up to 50 Amps per battery, and current per battery self-limits if you limit the voltage)
- Linear charge all the way from empty to full (all charge phases are the same - same ‘flat’ voltage).
- No need for any sort of battery ‘conditioning’ cycling at all
Charger settings:
- Set both absorption and float voltage to 57.6V
- disable storage mode.
- disable bulk protection(??)
Color Control GX
battery_compatibility/redflow_zbm.1465593279.txt.gz · Last modified: by mvader
Add this page to your book
Manage book (
Help
