battery_compatibility:redflow_zbm
battery_compatibility:redflow_zbm [2016-06-10 23:14] – created mvader | battery_compatibility:redflow_zbm [2019-01-21 10:39] – [Disqus] ictbeheer | ||
====== Victron & Redflow ZBM ====== | ====== Victron & Redflow ZBM ====== | ||
+ | http:// | ||
- | ===== Charge profile ===== | + | ==== Compatible Victron products |
+ | ==== Charge profile ===== | ||
+ | See the information | ||
- | Charger settings: | ||
- | - Set both absorption and float voltage to 57.6V | ||
- | - disable storage mode. | ||
- | - disable bulk protection(?? | ||
===== Color Control GX ===== | ===== Color Control GX ===== | ||
+ | Redflow ZBM batteries can be directly interfaced to the CCGX for monitoring and control (see below). | ||
+ | Alternatively one or more ZBM batteries can be used with the Redflow/ | ||
+ | For the direct-attach option, the Color Control GX has built in support for directly attaching to one or more Redflow ZBM batteries using the built in Modbus connection and protocol. | ||
+ | - Connect the CCGX to each battery in the system via Modbus-RS485, | ||
+ | - Monitoring the battery: battery voltage, current, state of charge, temperature and many more ZBM specific alarms and flags. | ||
+ | - Control the battery: set it to run mode, initiate a maintenance cycle, clear the alarms and more. | ||
+ | - Configure the battery: the CCGX will automatically assign a unique Modbus address to each battery. Just make sure to connect them, slowly, one by one. After connecting one, wait for it to show up on the CCGX, and then connect the next one. Additionally, | ||
battery_compatibility/redflow_zbm.txt · Last modified: 2021-03-20 02:50 by guystewart
