battery_compatibility:freedomwon
battery_compatibility:freedomwon [2019-05-05 13:16] – [Venus Device Configuration] freedomwon | battery_compatibility:freedomwon [2020-10-30 14:17] – Updated Venus OS for 2.60 warwickchapman | ||
====== Victron & Freedom Won LiFePO4 batteries - Freedom Lite ====== | ====== Victron & Freedom Won LiFePO4 batteries - Freedom Lite ====== | ||
+ | ===== Installers Note ===== | ||
+ | **Important: | ||
+ | Please take special and careful note of the section below on "DC bus pre-charging" | ||
Line 6: | Line 11: | ||
Freedom Won (www.freedomwon.co.za) produces two ranges of LiFePO4 batteries for 48V systems: | Freedom Won (www.freedomwon.co.za) produces two ranges of LiFePO4 batteries for 48V systems: | ||
- | * Freedom Lite Home and Business: Eight models available ranging from the smallest 5kWh model (Freedom Lite Home 5/4) up to the 80kWh model (Freedom Lite Business 80/56) | + | * Freedom Lite Home and Business: Eight models available ranging from the smallest 5kWh model (Freedom Lite Home 5/4) up to the 80kWh model (Freedom Lite Business 80/64) |
- | * Freedom Lite Commercial: | + | * Freedom Lite Commercial: |
//**Note: Refer to Freedom Won website for detailed specification sheets covering all models** | //**Note: Refer to Freedom Won website for detailed specification sheets covering all models** | ||
- | These Freedom Lite batteries are fully compatible with the Victron | + | These Freedom Lite batteries are fully compatible with the Victron |
- | The Freedom Lite batteries contain an advanced battery management system (BMS) that communicates, using a CAN Bus protocol, with the Victron | + | The Freedom Lite batteries contain an advanced battery management system (BMS) that communicates |
- | All Freedom Lite models can be connected in parallel with other models of the same capacity, where one Lite (Master) communicates with the Venus device as well as all the other Lite’s in the system (Slaves). | + | All Freedom Lite models can be connected in parallel with other models of the same capacity, where one Lite (Master) communicates with the GX device as well as all the other Lite’s in the system (Slaves). |
The Victron and Freedom Won integration has been extensively developed and tested and is certified and supported by both companies. | The Victron and Freedom Won integration has been extensively developed and tested and is certified and supported by both companies. | ||
The system is suitable for all applications, | The system is suitable for all applications, | ||
- | * Grid Connected with solar and storage including continued operation in grid outage (ESS or self-consumption mode) | + | * Grid Connected with solar and storage including continued operation in grid outage ([[https:// |
* Backup storage or UPS mode | * Backup storage or UPS mode | ||
* Off Grid plant with storage and solar | * Off Grid plant with storage and solar | ||
Line 35: | Line 40: | ||
===== This Manual ===== | ===== This Manual ===== | ||
- | This manual is intended to offer Victron specific guidance when designing, installing, and commissioning a Victron – Freedom Lite system. For further details pertaining to the setup of the Victron equipment not pertaining directly to the Freedom Lite interface please refer to the various manuals available on the Victron Energy website eg. Color Control GX manual. Likewise, for further information pertaining to the Freedom Lite batteries, please refer to the Freedom Lite installation manual available from Freedom Won ([[support@freedomwon.co.za]]). | + | This manual is intended to offer Victron specific guidance when designing, installing, and commissioning a Victron – Freedom Lite system. For further details pertaining to the setup of the Victron equipment not pertaining directly to the Freedom Lite interface please refer to the various manuals available on the Victron Energy website eg. [[https:// |
===== Product Compatibility ===== | ===== Product Compatibility ===== | ||
All new Victron equipment as follows is compatible with Freedom Lite: | All new Victron equipment as follows is compatible with Freedom Lite: | ||
- | • MultiPlus | + | * MultiPlus |
- | • MultiPlus II | + | |
- | • MultiPlus GX | + | |
- | • Quattro | + | |
- | • Blue Solar and Smart Solar Ve Direct | + | |
- | • Ve | + | * VE.Can MPPT’s |
- | • Color | + | * [[https:// |
- | • Venus GX | + | |
- | • Octo GX | + | |
- | //**Note**: Certain older Multiplus | + | //**NOTE**: Certain older MultiPlus |
- | //**Note**: If a system includes one or more Ve CAN MPPT’s it is necessary to request that Freedom Won dispatches the Lite from the factory with a profile accommodating 250kbps BAUD rate for the CAN Bus (the standard is 500kbps). This change can also be made remotely by Freedom Won with a local PC connected to the battery. Please contact support@freedomwon.co.za for assistance.// | + | //**NOTE**: If a system includes one or more **VE.CAN MPPTs** please carefully read the section below on VE.CAN MPPTs.// |
- | ===== Venus Device Required | + | ===== GX-Device Required ===== |
- | In all cases a Venus device is required to receive, process, and transmit the commands and information communicated by the battery to the Victron system. | + | In all cases a [[https:// |
===== Firmware ===== | ===== Firmware ===== | ||
Line 70: | Line 73: | ||
Further to above, the Lite should be sized so as to provide adequate energy capacity in kWh to meet the load demands of the system and to receive most of the excess solar generation each day (for self-consumption installations). | Further to above, the Lite should be sized so as to provide adequate energy capacity in kWh to meet the load demands of the system and to receive most of the excess solar generation each day (for self-consumption installations). | ||
- | //**Note**: It is not permissible to install an inverter larger than stated in the Lite specification sheet regardless of whether the “Limit DC Discharge Power” ESS feature in the Venus device is used. For instances where the grid is not available this power limiting feature will not operate and the battery could thus be overloaded, causing it to trip. The Lite will also not be able to limit discharge power in the absence of a grid connection. Lastly, the Lite contains a protection circuit breaker that is only rated to handle the power-up inrush current of the inverter for up to the capacity stated in the specification sheet.// | + | //**NOTE**: It is not permissible to install an inverter larger than stated in the Lite specification sheet regardless of whether the "Limit DC Discharge Power" |
- | ===== Operating Philosophy | + | ===== Victron-certified Integration |
- | The Freedom Lite transmits, amongst others, the following messages to the Venus device: | + | The Freedom Lite transmits, amongst others, the following messages to the [[https:// |
- | - Adaptive Maximum Charge Voltage | + | - Adaptive Maximum Charge Voltage |
- | - Charge Current Limit (CCL) – this is the maximum current that the battery will accept at any given time stated in Amps. This is a secondary control feature behind the more effective maximum charge voltage control method. This value reduces as the battery approaches 100% State of Charge (SoC). The Venus controller | + | - Charge Current Limit (CCL) – this is the maximum current that the battery will accept at any given time stated in Amps. This is a secondary control feature behind the more effective maximum charge voltage control method. This value reduces as the battery approaches 100% State of Charge (SoC). The GX-device |
- | - Discharge Current Limit (DCL) – this is the maximum discharge current that the battery is prepared to accept at any given time. This value typically decreases as the battery drops below 10% SoC. The Victron inverter cannot enforce a variable DCL unless in ESS mode were an AC input source can be used to supplement the power to the loads. If there is no AC input source the inverter will stop supplying power to the loads as soon as the DCL drops to zero. | + | - Discharge Current Limit (DCL) – this is the maximum discharge current that the battery is prepared to accept at any given time. This value typically decreases as the battery drops below 10% SoC. The Victron inverter cannot enforce a variable DCL unless in ESS mode were an AC input source can be used to supplement the power to the loads. If there is no AC input source the inverter will stop supplying power to the loads as soon as the DCL drops to zero. |
- | - Battery | + | - Additional |
- | - Minimum | + | - Battery |
- | - Battery | + | - Minimum battery voltage |
- | - Battery | + | |
- | - Battery | + | - Battery |
+ | - Battery | ||
+ | - Highest cell voltage | ||
+ | - Lowest cell voltage | ||
+ | - Highest probe temperature | ||
+ | - Lowest probe temperature | ||
+ | - Battery gross capacity | ||
+ | - Number of batteries online | ||
- | All of the above information can be viewed in the Freedom Lite device sub menus on the Venus device. | + | All of the above information can be viewed in the Freedom Lite device sub menus on the GX-device. |
- | Specific setup of the Venus device and the Multi/Quattro is required to ensure the required control is implemented. | + | Specific setup of the GX-device and the MultiPlus/Quattro is required to ensure the required control is implemented. |
If the CAN bus cable is removed or damaged the Victron inverters will shut down within 5 minutes. This prevents continued operation in the absence of communication from the battery. Likewise, the MPPT’s will stop producing power to the DC bus. | If the CAN bus cable is removed or damaged the Victron inverters will shut down within 5 minutes. This prevents continued operation in the absence of communication from the battery. Likewise, the MPPT’s will stop producing power to the DC bus. | ||
+ | ===== DC Bus Pre-charging ===== | ||
+ | The inrush current when switching on the battery breaker onto the DC bus is huge. This can cause damage to the breaker over time. So it is a Freedom Won requirement that the DC bus is pre-charged before switching on the battery. This is achieved by switching on the AC input to the inverters – the inverters will use the AC power to pre-charge their capacitors. This will eliminate the huge inrush current. The MPPTs can also be used for pre-charging by switching on the solar panels supply to the MPPTs. | ||
===== CAN Bus Wiring ===== | ===== CAN Bus Wiring ===== | ||
- | The connection of the Lite to the Venus device is extremely simple. A standard **straight through** CAT5e Ethernet cable is required of the desired length, with one end plugged into one of the RJ45 sockets on the Lite and the other end plugged into one of the CAN sockets on the Venus device. Note that the second RJ45 socket in each case must be fitted with an end of line 120Ω resistor. Two are supplied with each Venus device. If multiple batteries are installed in parallel the second RJ45 socket is used to link the next battery in the line onto the CAN Bus network. The termination resistor is installed in the last battery in the CAN Bus line. Refer to Lite installation manual for further information. | + | The connection of the Lite to the GX-device is extremely simple. A standard **straight through** CAT5e Ethernet cable is required of the desired length, with one end plugged into one of the RJ45 sockets on the Lite and the other end plugged into one of the CAN sockets on the GX-device. Note that the second RJ45 socket in each case must be fitted with an end of line 120Ω resistor. Two are supplied with each GX-device. |
- | Correct CAN Bus communication can be verified by observing whether the Freedom Lite battery is presented in the Venus device list under the name “Freedom Lite”. | + | |
- | ===== Ve Configure Settings ===== | + | **Note:** In the case of the Venus GX or Octo GX, if the VE.CAN ports (RJ45) are being used by MPPTs, the secondary CAN bus needs to be connected using the green terminal blocks. |
- | The Multi or Quattro devices must be set for operation with the Freedom Lite as follows (note that settings not directly related | + | If multiple batteries are installed in parallel |
- | ☛Disable Battery Monitor (the Ve Bus battery monitor is not required with a CAN Bus Lithium | + | Correct |
- | {{: | + | ===== Victron VE.CAN MPPTs and Freedom Won Batteries ===== |
- | ☛Set the Shut-Down, Low Restart, and pre-alarm voltages (the pre alarm only activates | + | **Note:** In this section, the reference to "Color Control GX" refers |
- | {{: | + | The Freedom Won Battery Management System is configured by default to communicate over CAN bus at a 500kbps baud rate. For systems using a Color Control GX and Victron VE.CAN MPPTs, it is possible to change the baud rate of the battery to 250kbps in order to accommodate the VE.CAN baud rate. **However**, |
- | ☛Charger Settings | + | If there are slave batteries on a system, then there are conflicting CAN messages on the bus, and it is necessary to split the battery on the CAN Bus from the devices on Victron' |
- | {{: | + | Systems with both VE.CAN MPPTs and more than one Freedom Lite battery require a GX device with a dual CAN Bus. The entire GX-device range with the exception of the Color Control GX and the GX built into the MultiPlus II GX have dual CAN buses. |
- | ☛Set Charger Settings as below (the charge voltage values are overridden by the Lite but should be set correctly regardless for redundancy. The charge current should be set according to the user’s requirements | + | Where batteries need to be configured with a profile accommodating 250kbps baud rate for the MPPTs on the CAN Bus (the standard is 500kbps), the change can be made either: |
+ | - at the time of ordering by requesting that Freedom Won dispatches the Lite from the factory with baud set to 250kbps; or | ||
+ | - the battery can be reconfigured remotely by Freedom Won with a local PC connected to the battery. | ||
+ | Please contact [[support@freedomwon.co.za|support@freedomwon.co.za]] for assistance. | ||
+ | ===== VEConfigure 3 Settings ===== | ||
+ | The MultiPlus or Quattro devices must be correctly configured for operation with the Freedom Lite as follows (note that settings not directly related to the Lite are not mentioned here and must be referenced in the [[https:// | ||
+ | The GX-device will use the battery monitor provided by the Freedom Won battery by default: | ||
+ | ☛ Since Venus OS 2.60, it is no longer necessary to disable the Battery Monitor. Whether it is on, or off, you can ignore it. | ||
+ | ☛ Set the Low Shut-Down, Low Restart, and Low Pre-alarm voltages. | ||
+ | ☛ Charger Settings | ||
+ | ☛ Set Charger Settings. | ||
+ | **Note:** only adjust these values | ||
- | ☛When setting up the ESS Assistant select LiFePO4 battery and enter the Ah value for the Lite (or the combination of Lite’s for a parallel battery system) as per the Ah rating provided in the Lite specification sheet eg. Lite 5/4 = 100Ah. | + | ☛ When setting up the ESS Assistant select LiFePO4 battery and enter the Ah value for the Lite (or the combination of Lite’s for a parallel battery system) as per the Ah rating provided in the Lite specification sheet eg. Lite 5/4 = 100Ah. |
- | ☛Select – Do not change battery type | + | ☛ Select – Do not change battery type |
☛Sustain Voltage = 50V | ☛Sustain Voltage = 50V | ||
- | ☛Enter Dynamic Cut-off values as below (usually the Lite will override these values, however they should be entered correctly for redundancy) | + | ☛ Enter Dynamic Cut-off values as below (usually the Lite will override these values, however they should be entered correctly for redundancy) |
- | ☛Restart Offset = 1,2V | + | ☛ Restart Offset = 2.0V |
- | ☛Go back to General and disable battery monitor again. | + | ☛ Go back to General and disable battery monitor again. |
- | ===== Venus Device Configuration ===== | + | ===== GX-Device |
- | It is very important that the following settings are entered correctly for proper functioning of the Lite communication interface: | + | NOTE: Venus OS 2.60 has important updates to the support for FreedomWon Batteries and it is strongly recommended that you make use of 2.60 or newer. |
+ | It is very important that the following settings are entered correctly for proper functioning of the Lite communication interface: | ||
- | ☛Settings → Services → CAN-bus Profile → CAN-bus BMS (500kbit/s) | + | ☛ Settings → Services |
- | //**Note**: For systems with VE Can MPPT’s, select 250kbit/s and ensure Lite profile is also set for 250kbit/s (check with Freedom Won or your Freedom Won distributor).// | + | //**Note**: For systems with VE Can MPPT's, select 250kbit/s and ensure Lite profile is also set for 250kbit/s (check with Freedom Won or your Freedom Won distributor).// |
- | ☛Confirm that the Freedom Lite is showing in the device list as per below | + | ☛ Confirm that the Freedom Lite is showing in the device list (top of the menu structure) |
- | ☛Settings → System Setup → Switch on DVCC and SVS, check that BMS Control is “On” | + | {{ : |
- | {{:battery_compatibility:freedom_won_venus_2.png? | + | ☛ Freedom Lite → Parameters → Confirm that the Charge Current Limit and Discharge Current Limit are as per the Lite specifications (Note: if the battery is fully charged the CCL may be reduced. Check that the voltage target is within the range 54.8V to 55.8V (Note: below about 95% SoC the value reflected should be 55.7 or 55.8V. For a fully charged battery this value should range from 55.0V to 55.8V depending on the state of balancing of the cells in the Lite. |
- | {{:battery_compatibility: | + | ☛ Confirm that DVCC is forced on at: Settings → DVCC |
- | ☛Freedom Lite (device list) → Parameters → Confirm that the Charge Current Limit and Discharge Current Limit are as per the Lite specifications (Note: if the battery is fully charged the CCL may be reduced. Check that the voltage target is within the range 54,1V to 55,8V (Note: below about 95% SoC the value reflected should be 55,7 or 55,8V. For a fully charged battery this value should range from 55,0V to 55,8V depending on the state of balancing of the cells in the Lite. | + | {{ :battery_compatibility:venus-3.png? |
===== MPPT Configuration ===== | ===== MPPT Configuration ===== | ||
- | The voltage setpoints on the MPPT’s must be set to 55,8V for bulk and float with equalization | + | The voltage setpoints on the MPPT's must be set to 55.8V for bulk and float with equalisation *disabled*. In order to do this on the VE.CAN MPPT's select the User Defined option 8 battery type as this allows adjustment of the charge voltage setpoints. |
- | Adjust the maximum current on the MPPT’s to ensure that the combined total charge power cannot exceed the maximum rated charge current for the Lite or Lite’s in the system. | + | Adjust the maximum current on the MPPT's to ensure that the combined total charge power cannot exceed the maximum rated charge current for the Lite or Lite’s in the system. |
===== Troubleshooting ===== | ===== Troubleshooting ===== |
battery_compatibility/freedomwon.txt · Last modified: 2024-02-08 14:12 by warwickchapman
