battery_compatibility:byd_b-box [2019-02-01 14:05] – [10. Known Issues] guy_stewart | battery_compatibility:byd_b-box [2020-03-18 17:34] – [5. GX device configuration] mvader | ||
The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | The combination of Victron products with BYD Battery-Box LV lithium batteries has been tested and certified by the Victron and BYD R&D departments. This combination has extensive field experience and is actively supported by both companies. | ||
- | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: | + | The BYD B-Box includes an integrated Battery Management System (BMS) with each battery cell module, and a Battery Management Unit (BMU) that interfaces with the Victron [[venus-os: |
- | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ | + | |
- | | Appearance | {{ : | + | |
- | | Grid Backup| | + | |
- | | Off-Grid| | + | |
- | | Max capacity| | + | |
+ | ^ Battery ^ Pro 2.5-10.0 ^ Pro 12.8 & 13.8 ^ L 3.5-14.0 ^ Premium LVL 15.4 ^ | ||
+ | | Appearance | {{ : | ||
+ | | ESS | yes| yes| yes| yes| | ||
+ | | Grid Backup| | ||
+ | | Off-Grid| | ||
+ | | Module capacity| | ||
+ | | Module limit | 32| 32| 12| 64| | ||
+ | | Max capacity| | ||
Line 27: | Line 23: | ||
* Off-grid | * Off-grid | ||
+ | === 1.2 A GX device is required, eg Cerbo GX, Color Control GX (CCGX), Venus GX (VGX), etc === | ||
- | === 1.2 A Venus-device is required, either Color Control GX (CCGX) or Venus GX (VGX) === | + | When used with B-Box Pro series |
- | It is essential to use the CAN-bus connection of the CCGX or VGX with the BYD batteries for the keep-alive signal, communication of charge and discharge limits, error codes and state of charge. | + | |
- | When used with B-Box batteries, the minimum | + | |
- | The minimum firmware version is 422. Though updating | + | The minimum |
- | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: | + | In grid connected systems, advanced control functions are configurable in the ESS settings on the [[venus-os: |
- | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: | + | In off-grid systems, the control functions of the BYD Battery Management System (BMS) are built into the latest version of the [[venus-os: |
- | === 1.4 All 48V BlueSolar and SmartSolar MPPT Chargers are compatible === | + | When planning |
- | For proper operation, the B-Box battery needs to be able to control the charge current of the solar MPPTs. | + | |
- | It is recommended | + | |
- | To test operation, try disconnecting the [[venus-os: | + | |
- | __MPPTs with a VE.Can | + | |
- | Firmware should be at least version 2.05. | + | |
- | When using VE.Can MPPT's, it is recommended to use the Venus GX (VGX), instead of the CCGX. The VGX has two CAN-bus interfaces available and allows communication between | + | |
Line 78: | Line 59: | ||
- | Minimum BYD firmware version: BMU_V2_V4-13_15-Mar-2017. | + | |
- | On-screen, or via Remote Console on the [[venus-os: | + | B-Box Pro BMU Firmware versions earlier than V4-13 are not compatible with Victron equipment and can cause the battery to not be detected. |
- | Batteries with older firmware versions can be updated. Please contact BYD for more information. | + | Minimum BYD firmware version for B-Box Pro: BMU_V2_V4-13_15-Mar-2017. On-screen, or via Remote Console on the [[venus-os: |
+ | BYD Premium LVL batteries firmware should be no less than V1.4, and the BMS firmware should be no less than V1.3. If necessary, this can be updated automatically via the ethernet port on the BMU when connected to the internet. | ||
Line 92: | Line 73: | ||
- | The following charge rates are managed automatically by the BYD BMU and [[venus-os: | + | The following charge rates are managed automatically by the BYD BMU and [[venus-os: |
Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMU triggering over-current alarms. | Using very large solar arrays with battery banks that are too small can exceed the limits of the batteries ability to charge and possibly lead to the BMU triggering over-current alarms. | ||
Line 102: | Line 83: | ||
|Phases| | |Phases| | ||
Line 144: | Line 124: | ||
Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | Minimum discharge SOC for 1 single Battery Box L 3.5 is 12%; for 2 or more (7kWh+) it can be 10%. | ||
- | Up to 5 L modules can be installed per L series BCU; 6 or more will require additional BCU. | + | Up to 4 L modules can be installed per L series BCU; 5 or more will require additional BCU. |
+ | |Phases| | ||
+ | | Inverter/ | ||
+ | | Multiplus 48/ | ||
+ | | Quattro 48/ | ||
+ | | EasySolar 48/ | ||
- | The specification for these minimum battery sizes was obtained from [[http:// | + | The specification for these minimum battery sizes was obtained from [[http:// |
+ | ===== 3. CAN-Bus wiring between the battery and GX Device ===== | ||
+ | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | ||
- | ===== 3. CANBus Wiring ===== | + | Then, plug a [[https:// |
- | Use the //VE.Can to CAN-bus BMS type A Cable//, part number ASS030710018. Plug the side which is labeled Battery BMS into the BYD BMS. Plug the side labeled Victron VE.Can into the [[venus-os: | + | |
- | Then, plug a [[https:// | + | |
- | It is important to ensure this connection and display of the battery on the [[venus-os: | + | |
- | === 3.1 Wiring of the Allow-to-charge and allow-to-discharge contacts === | + | |
- | Using the latest firmware on all devices, the BYD allow to charge contacts are only required when using VE.Can MPPT' | + | |
- | The MPPTs with a VE.Can port have a dedicated Remote On/Off input. It needs to be connected to battery positive to enable the charger. Leaving the Remote On/Off input floating or pulling it to ground will disable the charger. | + | |
- | B-Box relays: | + | |
Line 195: | Line 168: | ||
=== 4.2 Charge parameters === | === 4.2 Charge parameters === | ||
- | In normal operation, the charge parameters are controlled by the BYD BMU and communicated through the system by the [[venus-os: | + | In normal operation, the charge parameters are controlled by the BYD BMU and communicated through the system by the [[venus-os: |
Line 237: | Line 210: | ||
- | ===== 5. Venus-device | + | ===== 5. GX device |
Line 245: | Line 218: | ||
* Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | * Select the //CAN-bus BMS (500 kbit/s)// CAN-profile in the CCGX. Menu path: //Settings -> Services -> CAN-profile// | ||
Line 255: | Line 227: | ||
+ | Note these limits have been adjusted higher by BYD during firmware updates, so the charge and discharge current limit figure may appear slightly higher. | ||
Line 261: | Line 235: | ||
The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | The CCGX only has one available VE.Can port. It is not possible to connect both CAN products such as VE.Can MPPT (250 kbit/s) and an B-Box battery CAN-bus (500 kbit/s) together on the CCGX. As the BYD Battery MUST be connected, you will need to use the port for that. This will mean no data is collected from the VE.Can MPPT, nor can the CCGX control it. This means you are required to use the "Allow to Charge" | ||
- | === Venus GX Configuration | + | === GX Device with multiple CAN-bus port configuration |
- | The VGX has two CAN-bus interfaces available. The VE.Can MPPT will remain connected to the VE.Can port, while the BYD CAN-bus cable should use the specific CAN-bus connections (H, L, GND). | + | With GX devices that have two CAN-bus interfaces available |
- | This allows data from the MPPT and BYD battery simultaneously. You will only need to connect the Allow-to-charge wires if using the VE.Can MPPT and VGX. | + | |
- | The CAN-bus connections are galvanically isolated at the BYD BMU. There is no issues using the non-isolated connection of the VGX. | + | This allows data from the MPPT and BYD battery simultaneously. |
- | ===== 6. VE-Direct MPPT Settings ===== | + | The CAN-bus connections |
- | In normal operation the MPPT charge characteristics | + | |
- | This section presumes familiarity with [[victronconnect: | + | ===== 6. Solar Charger configuration ===== |
- | The settings below are a precautionary measure. | + | The MPPT charge characteristics are automatically configured & governed by the [[venus-os: |
- | ^MPPT Parameter ^ Setting ^ | + | ^ MPPT Parameter ^ Setting ^ |
- | |Battery voltage. |48V| | + | |Battery voltage |
Line 288: | Line 260: | ||
- | As a safety precaution, the inverter/ | + | As a safety precaution, the inverter/ |
- | You can then start the inverter/ | + | You can then start the inverter/ |
- | === Step 1. Check that the BYD battery is visible on the Venus-device list === | + | === Step 1. Check that the BYD battery is visible on the GX device list === |
Line 300: | Line 272: | ||
* BYD firmware version (see requirement above) | * BYD firmware version (see requirement above) | ||
* CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work. | * CAN-bus communication cabling between BYD and Victron system. Make sure that it is in the right way around. If the special cable is plugged in reversed it won't work. | ||
Line 307: | Line 279: | ||
=== Step 2. Check that the BYD battery is ready for use === | === Step 2. Check that the BYD battery is ready for use === | ||
When ready for use, the Max Charge Voltage will read 56.5 V. In case there is an error in the BYD system (wiring, addressing, or other), it will be 42 V: | When ready for use, the Max Charge Voltage will read 56.5 V. In case there is an error in the BYD system (wiring, addressing, or other), it will be 42 V: | ||
Line 313: | Line 285: | ||
- | Also check that your are seeing the expected | + | Also check that your are seeing the expected |
Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | Locally on-site, you can check the Run LED on the BYD BMU, it needs to be lit up continuously: | ||
Line 345: | Line 317: | ||
- | ===== 9. Step by Step Guide ===== | ||
- | If you need further details, a user contributed [[battery_compatibility: | + | ===== 9. Step by Step Installation Guide ===== |
+ | There is a step by step installation video that demonstrates the essential connections and programming that is required for installation of a BYD battery in a Victron system. It is accessible via the [[https:// | ||
+ | This written manual should be assumed to be the more accurate and up-to-date, if there are any discrepancies between the video and the written manual, | ||
===== 10. Known Issues ===== | ===== 10. Known Issues ===== | ||
=== 10.1 Inaccurate State of Charge (SoC) Readings === | === 10.1 Inaccurate State of Charge (SoC) Readings === | ||
- | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: | + | Each BYD battery module has it’s own BMS. This BMS reports it’s battery information to the BMU which is connected to the [[venus-os: |
Each BYD module BMS has a threshold current of 1A (~50W) before it begins to report. For multiple modules, this is additive. So 4 modules could supply a 180W load and report it as 0 W. | Each BYD module BMS has a threshold current of 1A (~50W) before it begins to report. For multiple modules, this is additive. So 4 modules could supply a 180W load and report it as 0 W. | ||
Line 367: | Line 346: | ||
=== Work-arounds === | === Work-arounds === | ||
- | If precise state of charge is important, it is possible to install a Victron BMV shunt, and program the [[venus-os: | + | If precise state of charge is important, it is possible to install a Victron BMV shunt, and program the [[venus-os: |
The limitations of this method are if cells are added, removed or shut down, the BMV will continue to report SoC based on the total Ah of storage set. | The limitations of this method are if cells are added, removed or shut down, the BMV will continue to report SoC based on the total Ah of storage set. | ||
Line 407: | Line 386: | ||
- | ===== 11. Further Information ===== | + | |
+ | === 10.4 Self-Startup from Low voltage shutdown modes === | ||
+ | If your system is supplied only with AC-bus solar charging, this may prevent the solar inverter from starting up to recharge the batteries. Therefore it is strongly recommended that there is also either a generator or DC MPPT charge controller to provide DC bus power to bring the inverter back online to allow normal recharging to resume. | ||
+ | ===== 11. Legacy systems using allow-to-charge and allow-to-discharge contacts ===== | ||
+ | The Remote On/Off input of the two mentioned solar charger models is used to signal that they can or cannot charge the battery. It needs to be connected to battery positive to enable the charger. Leaving the Remote On/Off input floating or pulling it to ground will disable the charger. | ||
+ | B-Box relays: | ||
+ | ===== 12. Further Information ===== | ||
For information about where to buy or find suitably qualified installers, visit the [[https:// | For information about where to buy or find suitably qualified installers, visit the [[https:// | ||
Line 416: | Line 426: | ||
