assistants:self_consumption_hub-1
assistants:self_consumption_hub-1 [2016-11-07 22:49] – mvader | assistants:self_consumption_hub-1 [2019-01-21 10:36] – [Frequently asked questions] ictbeheer | ||
Line 7: | Line 7: | ||
===== When to use the hub-1 Assistant? ===== | ===== When to use the hub-1 Assistant? ===== | ||
- | Use the Assistant for these systems with Solar chargers, | + | Use the Assistant for these systems with Solar chargers, |
- | * Grid that allows feed-back | + | |
- | * Grid that does not allow feed-back | + | |
- | * Grid + a backup generator | + | |
+ | Usage of all other policies of Hub-1 have been deprecated, in favor of [[ess: | ||
- | Do not use this Assistant for the following systems, even though they have solar chargers: | + | Besides below information, there is more information |
- | * No grid nor generator; solar only | + | |
- | * Only a generator connected to the ac-input of the Multi or Quattro, no grid. | + | |
- | More information: | + | |
- | * [[https:// | + | |
- | * [[assistants:self_consumption_hub-1_policy-5]] | + | |
+ | * [[assistants: | ||
===== Frequently asked questions ===== | ===== Frequently asked questions ===== | ||
Line 45: | Line 38: | ||
A maximum of 25 units can be connected in parallel. | A maximum of 25 units can be connected in parallel. | ||
assistants/self_consumption_hub-1.txt · Last modified: 2019-01-22 10:16 by 127.0.0.1
