assistants:how_to_add_and_configure_an_assistant
assistants:how_to_add_and_configure_an_assistant [2014-08-26 20:51] – mvader | assistants:how_to_add_and_configure_an_assistant [2019-01-21 10:35] – [Step by step instructions] ictbeheer | ||
Line 6: | Line 6: | ||
==== Prerequisite ==== | ==== Prerequisite ==== | ||
- | To work with Assistants, VE.Bus Multis, Inverters and Quattros must be loaded with a a different firmware first. More information about which firmware type to choose for an installation, | + | To work with Assistants, VE.Bus Multis, Inverters and Quattros must be loaded with a a different firmware first. More information about which firmware type to choose for an installation, |
Line 20: | Line 20: | ||
- | The assistant will appear in the ‘Used assistants’ box but it will be Italic since it has not been configured yet. | + | The assistant will appear in the ‘Used assistants’ box and it will be in italics, as it has not been configured yet. |
Now Click on Start assistant | Now Click on Start assistant | ||
Line 72: | Line 72: | ||
assistants/how_to_add_and_configure_an_assistant.txt · Last modified: 2021-09-17 09:11 by mvader
