assistants:how_to_add_and_configure_an_assistant
assistants:how_to_add_and_configure_an_assistant [2014-08-03 13:53] – mvader | assistants:how_to_add_and_configure_an_assistant [2019-01-21 10:35] – [Step by step instructions] ictbeheer | ||
Note: below screenshots are just an example. The same procedure works for other Assistants as well. The used example refers to an Assistant which has later been renamed to PV Inverter support, and is also rarely used on new installations. The Self-consumption Hub-2 Assistant is used instead. It is not necessary, nor possible, to combine it with the PV Inverter support Assistant. | Note: below screenshots are just an example. The same procedure works for other Assistants as well. The used example refers to an Assistant which has later been renamed to PV Inverter support, and is also rarely used on new installations. The Self-consumption Hub-2 Assistant is used instead. It is not necessary, nor possible, to combine it with the PV Inverter support Assistant. | ||
- | Note for three-phase and parallel systems: some Assistants need to be configured in in all Multis or Quattros in the system, others only in the master of L1 or in all masters. Carefully read the instructions in the Assistant pages while configuring. | + | Note for three-phase and parallel systems: some Assistants need to be configured in in all Multis or Quattros in the system, others only in the master of L1 or in all phase-masters. Carefully read the instructions in the Assistant pages while configuring. |
+ | ==== Prerequisite ==== | ||
+ | To work with Assistants, VE.Bus Multis, Inverters and Quattros must be loaded with a a different firmware first. More information about which firmware type to choose for an installation, | ||
Line 17: | Line 20: | ||
- | The assistant will appear in the ‘Used assistants’ box but it will be Italic since it has not been configured yet. | + | The assistant will appear in the ‘Used assistants’ box and it will be in italics, as it has not been configured yet. |
Now Click on Start assistant | Now Click on Start assistant | ||
Line 69: | Line 72: | ||
assistants/how_to_add_and_configure_an_assistant.txt · Last modified: 2021-09-17 09:11 by mvader
