actor_offgrid
actor_offgrid [2022-11-25 12:01] – bob | actor_offgrid [2023-10-25 15:36] (current) – bob | ||
Line 31: | Line 31: | ||
- | On the Multiplus or Quattro, using Ve.config, add the PV Inverter support Assistant | + | On the Multiplus or Quattro, using Ve.config, add the PV Inverter support Assistant. |
+ | -> The correct working of the frequency shift in the PV Inverter assistant needs to physically have a PV inverter installed on ACout which can feed into the Victron system. | ||
actor_offgrid.txt · Last modified: 2023-10-25 15:36 by bob
