Isolation Transformer
5. Technical specifications
In this section:
4500W auto 115/230V
AC input voltage *
115 or 230V, automatic detection
AC output voltage *
120 or 240V
Frequency
50/60Hz
Output current rating
38A (115V)
19A (230V)
Soft start
Yes
Operating temperature range
-20°C to 40°C
Humidity
Max 95%, non-condensing
Transformer type
Toroidal (low noise, low weight), 1:1.05 ratio
Enclosure
Aluminium (blue RAL 5012)
Protection category
IP21
Safety
EN 60076
Weight
21.8 kg
Dimensions (h x w x d), mm
362 x 258 x221
*) The isolation transformer can be used as:
  • 115V to 120V isolation transformer
  • 230V to 240V isolation transformer
  • 115V to 240V isolation transformer
  • 230V to 120V isolation transformer
