5. Technical specifications
In this section:
5.1. Technical specifications
Isolation Transformer | 2000W 115/230V |
AC input voltage * | 115 or 230V |
AC output voltage * | 120 or 240V |
Frequency | 50/60Hz |
Output current rating | 17A (115V) 8.5A (230V) |
Soft start | Yes |
Operating temperature range | -20°C to 40°C |
Humidity | Max 95%, non-condensing |
Transformer type | Toroidal (low noise, low weight), 1:1.05 ratio |
Enclosure | Aluminium (blue RAL 5012) |
Protection category | IP21 |
Safety | EN 60076 |
Weight | 12.7kg |
Dimensions (h x w x d), mm | 375 x 214 x 135 |
*) The isolation transformer can be used as:
115V to 120V isolation transformer
230V to 240V isolation transformer
115V to 240V isolation transformer
230V to 120V isolation transformer
