5. Product compatibility & data transmission to VRM
The GlobalLink 530 supports VE.Direct protocol and Instant Readout via Bluetooth. The latter is used for wireless data communication between the GlobalLink 530 and compatible smart devices. The data from devices connected via VE.Direct and Instant Readout can then be monitored via the VRM portal. See also the Victron smart devices and RuuviTags chapter.
VE.Direct (wired)
Supported data attributes for wired devices connected via VE.Direct:
VE.Direct device | Data attributes transmitted to VRM every 15 minutes |
MPPT solar charger | State, battery voltage, battery current, load current, solar yield, error code |
BMV / SmartShunt | Main (battery) voltage, auxiliary voltage, main (battery) current, load current, State of Charge, alarm reason |
Inverter (RS) | State, mode, battery voltage, AC output voltage, AC output current, warning reason, alarm reason |
Multi RS | State, battery voltage, battery current, AC output voltage, AC output current, error code |
Smart IP43 Charger | State, mode, battery voltage (up to 3 channels), battery current (up to 3 channels), error code |
Orion XS | State, mode, battery voltage, battery current, DC input voltage, DC input current, error code |
Note
Note: Even though the Peak Power Pack has a VE.Direct port, the GlobalLink is not compatible with it.
Instant Readout (Bluetooth)
Supported data attributes for Bluetooth devices connected via Instant Readout:
Bluetooth device | Data attributes transmitted to VRM every 15 minutes |
MPPT solar charger | State, battery voltage, battery current, PV power, load current, solar yield, error code |
BMV / SmartShunt | Main (battery) voltage, auxiliary voltage, main (battery) current, State of Charge, alarm reason |
Smart Battery Sense | Voltage, temperature |
Inverter (RS) | State, battery voltage, battery current, PV power, solar yield, AC output power, error code |
Multi RS | State, battery voltage, battery current, active AC input, AC input power, AC output power, PV power, solar yield, error code |
Smart IPxx Charger | State, battery current (up to 3 channels), battery voltage (up to 3 channels), error code |
Orion XS | State, input voltage, input current, output voltage, output current, off reason, error code |
Orion-Tr Smart | State, input voltage, output voltage, off reason, error code |
Lynx Smart BMS | Battery voltage, battery current, State of Charge, time-to-go, warnings & alarms, error code |
NG BMSes | Lynx Smart BMS NG, smallBMS NG, VE.Bus BMS NG: Battery voltage, battery current, State of Charge, Remaining time, warning & alarms, error code, Battery temperature, Consumed Ah |
Lithium SuperPack NG battery | Battery voltage, Battery current, State of Charge, Remaining time, Battery temperature, Consumed Ah |
Lithium Battery Smart | Battery voltage, cell voltage (up to 8 cells), balancer status, error code |
Smart BatteryProtect | State, output state, input voltage, output voltage, off reason, error code |
VE.Bus Smart Dongle | State, battery voltage, battery current, active AC input, AC input power, AC output power, State of Charge, alarm, error code |
RuuviTag | Temperature, humidity, pressure |
