Manual - EV Charging Station
6. Troubleshooting
In this section:
6.1. CP Line Calibration
Note
CP calibration is performed automatically every time an EV is connected to the EVCS. The Calibration button is hidden in the VictronConnect application and the web interface. However, it is still possible to perform manual calibration if you experience issues with EV detection. To do this, set Modbus TCP register 5133 to 0 (see section Q11: I would like to control the EVCS via Modbus TCP. Is this possible and if so, how?). This disables automatic CP calibration and makes the Calibration button available for manual calibration.
What is CP?
CP is the control pilot signal (line) inside each Type2 charger connector. It is a bi-directional communication line that enables communication between the charging station and the EV. Among other things, the charging station informs the EV of the maximum charging current available. At the same time, the EV informs the charging station about its status, for example whether the EV is connected or whether it is currently charging.
Why is CP line calibration necessary?
Due to differences in cable length and manufacturer as well as deviations in the ratings of electronic components, the CP signal may show deviations. The CP calibration takes the signal deviation into account and adjusts the signal values to the required ranges.
When does the calibration of the CP line have to be carried out?
There are several reasons for a CP line calibration. The most important are:
  • The EV is connected to the EVCS via the charging cable, but still reports a disconnected state
  • The EV was disconnected from the EVCS but was not reported as disconnected.
  • When charging the EV, the EVCS frequently switches between the 'charging' and 'charged' states
  • The EVCS does not start charging after connecting the vehicle because it cannot detect the correct state after connection
How is a CP line calibration carried out?
Please see the note above for instructions on how to enable the manual calibration feature.
The CP calibration can be done via the web interface (Settings → General → Charger → CP calibration or via VictronConnect (Settings page). The procedure is as follows:
  1. Press the calibration button
  2. Connect the EV to the EVCS and then tap on Next in VictronConnect
  3. Press the 'Vehicle is connected' button to confirm that the EV is indeed connected to the EVCS (or tap on Next in VictronConnect)
  4. Wait until the EVCS has completed the calculation
    Once the calibration is complete, a message is displayed indicating that the calibration was successful
EVCS_CP_Calibration_VC.svg
EVCS_CP_Calibration_GUI.svg
6.2. MQTT pairing
If pairing does not succeed, check the firmware and app versions given in the MQTT activation section first.
No GX devices found after discovery
  • Check that the EV Charging Station and the GX device are on the same network and the same subnet.
  • Check the WiFi signal strength of the EV Charging Station. A value better than -70 dBm is preferable.
  • Run the discovery a few times.
  • Some networks block mDNS packets, which the discovery depends on.
  • If the discovery still finds nothing, enter the IP address and VRM Portal ID of the GX device by hand.
Errors during pairing
  • Check that pairing mode is still active on the GX device. It times out after two minutes.
  • Pairing errors are shown with an error code and the reason.
  • A message reading only 'Pairing error' indicates an internal error. Check the versions, retry the pairing, refresh the web interface or reconnect VictronConnect.
W-104: GX communication warning
Communication between the EV Charging Station and the GX device is not working.
  • Check that both devices are on the same network.
  • Check that the IP address and VRM Portal ID of the GX device stored on the EV Charging Station are correct.
  • Check that the EV Charging Station is still in the paired devices list on the GX device.
  • Repeat the pairing procedure, see MQTT activation.
6.3. Frequently asked questions
6.3.1. Q1: How do I prevent the charging station from being used by unauthorised persons?
Make sure EV charger autostart is disabled in general settings. This prevents the charging station from starting to charge automatically once it is connected to an EV.
Charging can then only be started or stopped via the web interface, VRM App widget, VRM controls and VictronConnect.
6.3.2. Q2: Does the EV Charging Station have RFID?
Yes, NFC tags can be used to control the ability to start charging sessions.
6.3.3. Q3: The light ring is annoying my neighbours during night, how can I disable the light ring?
You can completely disable the light ring in the light ring menu, changing the brightness to 0 or a lower level if you like.
6.3.4. Q4: Why isn't my car recognized when I connect the charging cable?
Try calibrating the CP line (general tab in the web interface or in the VictronConnect settings). This is sometimes necessary because the charging cables can differ slightly. Ground impedance is also important as all measurements are relative to ground (GND).
6.3.5. Q5: Why does my EV Charging Station show up on multiple GX devices?
If there are several GX devices on the same local network, there are different ways to ensure that only the intended GX device communicates with the EVCS.
  1. Use direct MQTT communication with the selected GX device. This way, other GX devices will not be able to connect to the EVCS.
  2. If the EVCS is still using Modbus communication, go to GX Device Settings → Integrations → Modbus Devices → Discovered Devices. There is an option to deactivate the EVCS. After deactivation, the GX device will stop communicating with it, and the EVCS can be removed from the device list.
  3. Use the method already described in the manual, but only if the EVCS is still using Modbus communication.
6.3.6. Q6: How much PV power do I need at least to charge the EV in automatic mode?
The minimum current for charging an EV is 6A@230V. You therefore need more than 1.3kW of PV.
However, if there is not enough excess solar power available to meet the minimum charge current requirement, it is possible to enable the 'Allow low excess solar power for auto mode' option. This option supplements the required power with additional power from the grid to meet the minimum current requirement. See chapter VictronConnect setup, configuration and operation for details.
Example: To charge the EV at 6A while there is only 800W of excess solar power, 580W will be drawn from the grid to reach the required 1380W.
Note that there are EVs that require an even higher minimum charging current, e.g. the Renault Zoe; 10A.
6.3.7. Q7: Is it possible to operate multiple EV Charging Stations in one system?
Yes, this is possible. The available power is then shared between them.
6.3.8. Q8: The EV is fully charged, but the EVCS still alternates between start charging and stop charging, why?
The reason is most likely that the EVCS cannot correctly decode the 'charged' signal coming from the EV. Perform the CP line calibration to remedy the problem.
6.3.9. Q9: I keep getting a W-104 GX communication warning! What is the reason for this?
This warning indicates that the EVCS cannot read data from the GX device due to a communication problem, even though communication with the GX device is enabled in the EVCS web interface.
The remedy depends on the communication method in use.
MQTT
The pairing between the EV Charging Station and the GX device may have been lost, or may never have completed. See MQTT pairing
Modbus TCP
To remedy the problem, make sure that the IP address specified in the general settings of the web interface matches that of the GX device. Use the Discover function to allow the EVCS to derive the correct IP address from the VRM Portal ID - for more details, see the EV Charging Station setup chapter. Also make sure that ModbusTCP is enabled in the GX device itself.EV Charging Station setup web interfaceModbus TCP activation
6.3.10. Q10: Is a GX device in the system absolutely necessary?
This depends on the operation mode.
For automatic mode, communication between a GX device and the EVCS is mandatory. For manual and scheduled mode, a GX device can be installed, but does not have to be.
6.3.11. Q11: I would like to control the EVCS via Modbus TCP. Is this possible and if so, how?
Yes, this is possible. Modbus TCP offers a much higher degree of flexibility and control and provides access to a broader range of settings than what is described in the manual or available through the normal user interfaces.
Important
Note that changes to the settings via Modbus TCP will void any support.
The recommended method for support on Modbus-TCP questions is to use the Modifications section on Victron Community. Its frequently visited by many people using Modbus TCP and other methods of integrating with Victron products.
The EVCS Modbus TCP register list can be downloaded from the product page in the download area.
6.4. EVCS Notification, Warning, Alarm and Error Codes
The table below lists all possible warnings, alarms and error codes displayed in VictronConnect, a GX device or the web interface, which can be used for quick diagnosis and help with troubleshooting.
Errors
VictronConnect code
GX device code
Generic code
Message
Instructions/Remarks
E-01
#01
01
GND not present
Appears when the EVCS detects missing PE.
Contact the installer.
E-02
#02
02
Welded contacts
Appears when the EVCS detects welded contacts of the power relay.
E-03
#03
03
CP input short-circuit
Appears when the EVCS detects CP input shorted.
E-04
#04
04
Residual current
Appears when the EVCS detects residual current.
E-05
#05
05
Over temperature
Appears when the EVCS detects overheating.
Remove EVCS from direct sunlight or contact the installer.
E-06
#06
06
Light sensor IC fault
Appears when the EVCS can't communicate with the light sensor IC (applied only for the United Kingdom of Gr. Brit. and N. Ireland).
Contact installer.
E-07
#07
07
Tamper detected
Appears when the EVCS detects tampering (applied only for the United Kingdom of Gr. Brit. and N. Ireland).
Contact installer.
E-31
#31
31
Welded contacts L1
Appears when the EVCS detects welded contacts of the power relay on L1.
Contact installer.
E-32
#32
32
Welded contacts L2
Appears when the EVCS detects welded contacts of the power relay on L2.
Contact installer
E-33
#33
33
Welded contacts L3
Appears when the EVCS detects welded contacts of the power relay on L3.
Contact installer
E-34
#34
34
Welded contacts neutral
Appears when the EVCS detects welded contacts of the power relay on neutral.
Contact installer
E-35
#35
35
L1 - N reversed
Appears when the EVCS detects that the L1 and Neutral lines are swapped at the mains input.
Contact installer
E-36
#36
36
L1 - N reversed and / or no GND
Appears when the EVCS detects wrong conditions on the mains input, but can’t recognize the exact reason.
Check the mains wiring: ensure that Phase (L1) is connected to the L1 input and Neutral (N) to the N input.
Check that the PE line is connected to the PE input.
Contact installer
E-37
#37
37
RCD IC fault
Appears when the EVCS detects an RCD IC fault.
Contact installer
E-38
#38
38
EV cable fault
Appears when the EVCS detects a faulty diode in the EV cable.
Warnings
VictronConnect code
GX device code
Generic code
Message
W-101
#101
101
Initial setup not completed
Appears when the initial setup is not finished.
Perform initial setup.
W-102
#102
102
EVCS externally blocked by grid operator
Appears when EVCS is locked externally by the grid operator.
Contact your grid operator.
W-103
#103
103
EVCS high temperature detected
Appears when a high temperature is detected in the EVCS box, but the temperature is not yet critical to stop charging.
Remove EVCS from direct sun light or contact installer.
W-104
#104
104
Appears when communication with GX is enabled but not present.
Check GX device IP address and VRM portal ID configuration.
W-105
#105
105
Overload detected
Appears when EVCS detects overload.
W-106
#106
106
Overload active
Appears when EVCS detects overload and it is active.
W-107
#107
107
Scheduled mode failed - time sync issue
Appears when EVCS can’t synchronise the local date/time and the user switches to scheduled mode.
W-108
#108
108
The charging current is limited by an external switch
Appears when EVCS. is charging and the limit was activated by a special HW switch or over Modbus TCP. Currently only for Germany.
W-109
#109
109
The charging current is limited due to inverter overtemperature
Appears when EV is charging and inverter reported overtemperature
Notifications
VictronConnect code
GX device code
Generic code
Message
N-301
#301
301
Auto mode not available
Appears when attempting to set Auto mode but GX communication is disabled.
Enable communication with GX device.
N-302
#302
302
Scheduled mode not configured
Appears when trying to set Scheduled mode but the scheduler is not yet configured.
Add configuration for Scheduled mode.
N-303
#303
303
Car disconnected - can't start charging
Appears when the 'Start' button is pressed but the car is not connected to EVCS.
Connect the car.
N-304
#304
304
Charger error
Appears when the 'Start' button is pressed but the EVCS has an error.
Check errors and resolve them; contact the installer.
N-305
#305
305
Appears when the 'Start' button is pressed but the EVCS initial setup procedure is not finished yet.
N-306
#306
306
Charging will start according to scheduler settings
Appears when the 'Start' button is pressed but the EVCS is in Scheduled mode.
Switch mode to ‘Manual’ if you want to control charging.
N-307
#307
307
Overload active - can't start charging
Appears when the 'Start' button is pressed but an overload is active.
N-308
#308
308
Display FW is updating - can't start charging. Try again after a while.
Appears when the user presses the 'Start' button and display FW is updating.
