3. Features
Bluetooth setup and monitoring (Using VictronConnect)
Equipped with integrated Bluetooth; enabling quick and simple setup, advanced configuration, comprehensive monitoring and firmware updates via the VictronConnect app and a Bluetooth enabled device (mobile phone or tablet).
Integrated charge presets
Integrated charge presets (selected via the VictronConnect app) combined with adaptive charge logic are well suited for most common battery types; such as LiFePO4, AGM, Gel and flooded lead-acid. Advanced configuration with specific user defined settings is also possible using VictronConnect.
Multi-stage charge algorithm
The multi-stage charge algorithm is specifically engineered to optimise each recharge cycle and charge maintenance over extended periods.
Adaptive absorption
Adaptive absorption monitors the battery’s response during initial charging and intelligently determines the appropriate absorption duration for each individual charge cycle. This ensures that the battery is fully recharged regardless of the discharge level or capacity and avoids excessive time at the elevated absorption voltage (that can accelerate battery aging).
Temperature compensation
Charge voltage is automatically compensated depending on the ambient temperature; this ensures that the battery is charged at the optimal charge voltage regardless of the climate and avoids the need for manual settings adjustments. Temperature compensation is not required and automatically disabled when in LI-ION charge mode.
High efficiency
The Blue Smart IP67 Charger range is up to ~96% efficient; resulting in lower power usage, less heat generated and cooler operation
Durable and safe
Engineered to provide years of trouble-free and dependable operation in all usage conditions:
Protection against overheating: Output current will be derated if the ambient temperature increases above 40°C (linear derate from 100% at 40°C to 25% at 60°C)
Protection against output short circuit: If a short circuit condition is detected the charger will shut down
Protection against reverse polarity connection: If the charger is incorrectly connected to a battery with reverse polarity the output fuse will blow (fusing strategy varies per model, refer to the 'Technical specifications' section for more information)
Protection against ingress of dust and water/liquid
Silent operation
Silent operation since there is no cooling fan, cooling is via natural convection; full rated output current is still provided up to an ambient temperature of 40°C.
Note some Blue Smart IP67 Charger models feature an output protection relay, and an audible click may be heard when this relay changes state.
Lithium Ion compatible
Compatible with Li-ion (LiFePO₄) batteries; when the integrated LI-ION charge mode is selected the charge cycle settings are altered to suit.
If the charger is connected to a battery where under voltage protection (UVP) has tripped, it will automatically reset UVP and start charging; many other chargers will not recognise a battery in this state.
Warning: Do not charge Li-ion batteries if the battery temperature is below 0°C.
Storage stage
An additional stage to extend battery life whilst the battery is unused and on continuous charge.
Recondition stage
An optional stage that can partially recover/reverse lead acid battery degradation due to sulfation; typically caused by inadequate charging or if the battery is left in a deeply discharged state.
Configurable output current
An optional 'Low current' mode that limits the maximum charge current to a significantly reduced level; beneficial when charging lower capacity batteries with a high current output charger.
Recovery function
The charger will attempt to recharge a severely discharged battery (even down to 0V) with low current and then resume normal charging once the battery voltage has risen sufficiently; many other chargers will not recognise a battery in this state.
Power supply mode
A specific mode to use the charger as a DC power supply; to power equipment at a constant voltage with or without a battery connected.
Start interrupt output
The 12/25(1+Si) and 24/12(1+Si) models feature a start interrupt output in addition to the main charge output; a current limited output that is active only when the charger is connected to mains. It is typically used to drive a relay, either to warn the driver or to interrupt the start circuit of the vehicle, so that the engine cannot be started while the vehicle is still plugged in. Refer to the Start interrupt output section for more information.
