Electrical | 12/7 | 12/13 | 12/17 | 12/25 | |
Mains power voltage (Nominal | Min/Max) | 110 - 120VAC | 100 - 130VAC | ||||
Mains power frequency (Nominal | Min/Max) | 50 - 60Hz | 45 - 65Hz | ||||
Power factor | >0.6 | ||||
Standby power | 0.5W | ||||
Max efficiency | 93% | 95% | |||
Charge voltage (Absorption | Float | Storage) | Normal | 14.4V | 13.8V | 13.2V | |||
High | 14.7V | 13.8V | 13.2V | ||||
Li-ion | 14.2V | N/A | 13.5V | ||||
Temperature compensation (N/A for Li-ion) | -16mV/°C (-9mV/°F) | ||||
Charge algorithm | 6-stage adaptive (3 stage for Li-ion) | ||||
Charge current limit (in selected mode) | Max | 7A | 13A | 17A | 25A |
Low | 2A | 4A | 6A | 10A | |
Max battery capacity (≥0.1C in max mode) | 70Ah | 130Ah | 170Ah | 250Ah | |
Min battery capacity - Lead-acid (≤0.3C in selected mode) | Max | 23Ah | 43Ah | 57Ah | 83Ah |
Low | 7Ah | 13Ah | 20Ah | 33Ah | |
Min battery capacity - Li-ion (≤0.5C in selected mode) | Max | 14Ah | 26Ah | 34Ah | 50Ah |
Low | 4Ah | 8Ah | 12Ah | 20Ah | |
Fault protection | Reverse polarity (fuse), output short circuit and over temperature | ||||
Communication | Bluetooth (via VictronConnect app) | ||||
Bluetooth power and frequency | +4dBm | 2402 - 2480MHz | ||||
Cooling | Convection (no fan) | ||||
Operating temperature range | -20 to 60°C (-4 to 140°F) with full rated output up to 40°C (104°F) | ||||
Max humidity | 100% | ||||
Pollution degree (PD) | 2 | ||||
Overvoltage category (OVC) | II | ||||
Physical | |||||
Material and colour | Aluminium | Blue RAL 5012 | ||||
Mains power connection | 1.5m (5ft) mains cable with US NEMA 5-15P plug | ||||
Battery connection | Type | 1.5m (5ft) figure-8 red/black cable with M8 ring terminals | |||
Cable | 12 AWG | 9 AWG | |||
Output fuse rating (Internal fuse is not serviceable) | Internal | No | No | 35A | 30A |
Cable | 20A | 20A | 30A | No | |
Ingress protection (IP) rating | IP67 | ||||
Weight | 1.8kg (4.0lb) | 2.4kg (5.3lb) | |||
Dimensions (h x w x d) | 85 x 211 x 60 mm (3.3 x 8.3 x 2.4 inch) | 99 x 219 x 65 mm (3.9 x 8.6 x 2.6 inch) | |||
Compliance | |||||
Safety | UL1236, CSA22.2, SAE J1171:2016-09 | ||||
EMC | FCC15B, ICES-003 | ||||
Electrical | 24/5 | 24/8 | 24/12 | |
Max efficiency | 94% | 96% | ||
Charge voltage (Absorption | Float | Storage) | Normal | 28.8V | 27.6V | 26.4V | ||
High | 29.4V | 27.6V | 26.4V | |||
Li-ion | 28.4V | N/A | 27.0V | |||
Temperature compensation (N/A for Li-ion) | -32mV/°C (-18mV/°F) | |||
Charge current limit (in selected mode) | Max | 5A | 8A | 12A |
Low | 2A | 3A | 4A | |
Max battery capacity (≥0.1C in max mode) | 50Ah | 80Ah | 120Ah | |
Min battery capacity - Lead-acid (≤0.3C in selected mode) | Max | 17Ah | 27Ah | 40Ah |
Low | 7Ah | 10Ah | 13Ah | |
Min battery capacity - Li-ion (≤0.5C in selected mode) | Max | 10Ah | 16Ah | 24Ah |
Low | 4Ah | 6Ah | 8Ah | |
Physical | ||||
Output fuse rating (Internal fuse is not serviceable) | Internal | No | 25A | 30A |
Cable | 20A | 20A | 25A | |
Compliance | ||||
