In this section:
Supported devicesGX device setup via MQTTGX device setup via Modbus TCPSupported devicesRequirementsConfiguring a Shelly Gen2 Pro, Gen3, Gen4, or BLU deviceConfiguring a Shelly Gen2 Plus deviceConfiguring the GX deviceSwitching between the local Bluetooth adapter and the BridgeRequirementsSupported productsRequirementsConfigurationAvailable dataNMEA 2000 E-Drive compatibility requirementsInverter/chargersInvertersBattery monitorsSolar chargersOrion XS DC-DC Battery ChargersTank level dataOther data and product typesGX deviceInverter/charger systemBattery systemPhotovoltaic (PV) systemSupported load typesPause if no AC input is connectedNominal inverter utilisation limitPause after several days without full chargePriority relative to the batteryPriority-Aware Best FitActivate following loads when battery reachesReserve for battery chargingMaximum charging powerRemember detected EV phasesExpected power consumptionMinimum run duration when turned onMinimum rest duration when turned offRecommendation for multiple loads:System incompatible with Opportunity LoadsfffffffAC (Alternating Current)AssistantBatteryLifeBLE (Bluetooth Low Energy)BMS (Battery Management System)BMVCAN busCCGX (Color Control GX)CCL (Charge Current Limit)CVL (Charge Voltage Limit)DCL (Discharge Current Limit)DGN (Data Group Number)DHCP (Dynamic Host Configuration Protocol)Digital inputDVCC (Distributed Voltage and Current Control)EEBUSEGXESS (Energy Storage System)EVCS (EV Charging Station)GPSGX deviceIO ExtenderIP rating (Ingress Protection rating)J1939LAN (Local Area Network)LTE (Long-Term Evolution)MFD (Multi-Function Display)MK3-USBModbus TCPMPPT (Maximum Power Point Tracking)MQTTMulti / QuattroNMEA 2000NO / NC (Normally Open / Normally Closed)Node-REDOpportunity LoadsPGN (Parameter Group Number)Remote ConsoleRGBW / CCTRS485RV-C (Recreational Vehicle Controller Area Network)SCS (Shared Current Sense)SoC (State of Charge)STS (Shared Temperature Sense)SVS (Shared Voltage Sense)TCP / UDPUSBVE.BusVE.CanVE.DirectVenus OSVRM (Victron Remote Management)WiFi Access Point
