vrm_portal:vrm_world
vrm_portal:vrm_world [2016-01-22 15:34] dvdgiessenvrm_portal:vrm_world [2019-01-22 10:16] (current) – external edit 127.0.0.1
 ====== VRM World ====== ====== VRM World ======
-Now available at [[https://vrm.victronenergy.com/world/|vrm.victronenergy.com/world]].+VRM World is a way to publicly share your VRM site data to the world via a searchable world map. Naturally access to your site configuration, precise location and any private details are excluded.
 +{{ :vrm_portal:vrm_world.png |}}
 +Visit VRM World at [[https://vrm.victronenergy.com/world/|vrm.victronenergy.com/world]].
 In order for your site to show up on VRM World, it needs to: In order for your site to show up on VRM World, it needs to:
Line 8: Line 12:
   * Have fresh data (last update within the last 24 hours)   * Have fresh data (last update within the last 24 hours)
   * Have data for at least one of the following: solar yield, battery SOC, AC power in or consumption   * Have data for at least one of the following: solar yield, battery SOC, AC power in or consumption
-  * Have its location configured (set in VRM or via a connected GPS)+  * Have its location configured (set manually in VRM or via a connected GPS)
 Sites which do not meet these requirements (anymore) will be hidden on VRM World. Whenever they meet the requirements (again), they will show up again. If your site isn't visible despite having enabled sharing, please check that it meets the other requirements. Sites which do not meet these requirements (anymore) will be hidden on VRM World. Whenever they meet the requirements (again), they will show up again. If your site isn't visible despite having enabled sharing, please check that it meets the other requirements.
Line 18: Line 22:
 Here, enable the option to 'Share publicly on VRM World': Here, enable the option to 'Share publicly on VRM World':
-{{ :vrm_portal:vrm-share-your-site.png?nolink |}} +{{ :vrm_portal:share_your_site.png?nolink&550 |}}
 What happens when you share your site on VRM World? What happens when you share your site on VRM World?
   - It will be shown on the digital globe on [[https://vrm.victronenergy.com/world/|vrm.victronenergy.com/world]].   - It will be shown on the digital globe on [[https://vrm.victronenergy.com/world/|vrm.victronenergy.com/world]].
   - Anyone will be able to click the 'Visit' button and see all the sites data, similar to using a private sharing link.   - Anyone will be able to click the 'Visit' button and see all the sites data, similar to using a private sharing link.
-    * The exact location will not be shown, and of course visitors will not be able to change any settings, etc.+    * The precise location will not be shown, and of course visitors will not be able to change any settings, see phone numbers or other privacy sensitive information.
 ~~DISQUS~~ ~~DISQUS~~
vrm_portal/vrm_world.1453473297.txt.gz · Last modified: 2016-01-22 15:34 by dvdgiessen
