vrm_portal:two-step-verification
vrm_portal:two-step-verification [2015-07-03 13:34] – Page name changed from vrm_portal:two-factor-login to vrm_portal:two-step-verification mvader | vrm_portal:two-step-verification [2017-02-06 20:57] – thlassche | ||
====== Two-step verification ====== | ====== Two-step verification ====== | ||
- | Protect your account against unauthorized access with two-step verification. | + | Protect your account against unauthorized access with two-step verification. |
This manual describes how two-step authentication can be switched on or off for your VRM account. The different steps are described in order of execution and shown below using multiple screenshots. | This manual describes how two-step authentication can be switched on or off for your VRM account. The different steps are described in order of execution and shown below using multiple screenshots. | ||
- | ===== How to turn on Two-step verification ===== | + | ===== How to turn on two-step verification ===== |
==== Step one ==== | ==== Step one ==== | ||
Log into your account at https:// | Log into your account at https:// | ||
- | Once logged in, you will be redirected to your VRM homepage, shown in the image below. On this page select ' | + | Once logged in, you will be redirected to your VRM homepage, shown in the image below. On this page select ' |
- | {{:vrm:untitled-1.jpg|{{: | + | |
+ | {{ :vrm_portal:two-1.png? | ||
==== Step two ==== | ==== Step two ==== | ||
- | After selecting ' | + | After selecting ' |
- | {{:vrm:2.jpg|}} | + | |
+ | {{ :vrm_portal:two-2.png? | ||
==== Step three ==== | ==== Step three ==== | ||
On the following page there will be an ' | On the following page there will be an ' | ||
- | {{:vrm:3.jpg|}} | + | |
+ | {{ :vrm_portal:two-3.png? | ||
==== Step four==== | ==== Step four==== | ||
- | Now choose your country and then enter your mobile phone number. Submit this information by pressing 'Send verification code'. The VRM system will then send a verification code to your phone via a text message (SMS). In case you do not receive a code, you can press ' | + | Now choose your country and then enter your mobile phone number. Submit this information by pressing 'Next'. The VRM system will then send a verification code to your phone via a text message (SMS). |
- | {{:vrm:4.jpg|{{: | + | {{ :vrm_portal:two-4.png?nolink& |
==== Step five==== | ==== Step five==== | ||
- | After entering the code and pressing 'Verify' the VRM system will notify you of successfully enabling two-step verification. You can now select ' | + | After entering the code and pressing 'Next' the VRM system will notify you of successfully enabling two-step verification. You will automatically be redirected |
- | {{:vrm:6.jpg|}} | + | |
+ | {{ :vrm_portal:two-5.png? | ||
===== How to Turn off two-step verification ===== | ===== How to Turn off two-step verification ===== | ||
- | If you would like to turn off two-step verification you can do so by returning to your profile and once again access 'Two-step verification' | + | If you would like to turn off two-step verification you can do so by returning to your profile and once again access '2-step verification' |
- | {{:vrm:7.jpg|}} | + | |
+ | {{ :vrm_portal:two-7.png? | ||
+ | ~~DISQUS~~ |
vrm_portal/two-step-verification.txt · Last modified: 2023-06-08 13:07 by martijncoster
