vrm_portal:remote-veconfigure
vrm_portal:remote-veconfigure [2019-03-25 12:07] – [3. System shutdown during reconfiguration] Added reset issue jpasop | vrm_portal:remote-veconfigure [2020-03-15 09:22] – [1. Introduction] mvader | ||
Line 5: | Line 5: | ||
- | This functionality requires a [[venus-os: | + | This functionality requires a [[venus-os: |
- | - Venus OS v2.17 or later | + | - A GX Device running |
- Two way communication must be enabled | - Two way communication must be enabled | ||
- | - The [[venus-os: | + | - The [[venus-os: |
+ | - [[https:// | ||
Details: | Details: | ||
Line 21: | Line 22: | ||
- | In some cases the VE.Bus system will momentarily switched off when changing the configuration. See step 4 for more details. | + | In some cases the VE.Bus system will momentarily switched off when changing the configuration. |
===== 2. Step by step procedure ===== | ===== 2. Step by step procedure ===== | ||
Line 29: | Line 30: | ||
- Check the requirements | - Check the requirements | ||
- Venus OS v2.17 or later | - Venus OS v2.17 or later | ||
- | - Two way communication enabled (see Settings -> Services on the [[venus-os: | + | - Two way communication enabled (see Settings -> Services on the [[venus-os: |
- Two way communication up & running: check on the Device list page on VRM | - Two way communication up & running: check on the Device list page on VRM | ||
- On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | - On the VRM Portal, go to Device List, and scroll to the bottom to find the Remote VEConfigure button on the VRM Portal | ||
Line 35: | Line 36: | ||
- the system starts with reading all the settings of each inverter/ | - the system starts with reading all the settings of each inverter/ | ||
- once all data has been gathered; its compiled into a file and uploaded to your computer. | - once all data has been gathered; its compiled into a file and uploaded to your computer. | ||
- | - Download the file to your computer | + | - Download the .RSVC file to your computer |
- | - Modify the configuration, | + | - Modify the configuration, |
- | - Upload the file to the system | + | - Upload the .RVSC file to the system |
+ | - Be Aware - If the file is saved via the File, Save As menu, instead of closing VEConfigure and confirming the changes, it will save to a new .VSC file. This file can be opened, adjusted, and used to update locally with an MK3 adapter, but it cannot be uploaded to update a remote unit. You must use the .RVSC file downloaded from the system that you intend to change the settings of, and then upload that same file once changes are made. | ||
===== 3. System shutdown during reconfiguration ===== | ===== 3. System shutdown during reconfiguration ===== | ||
Line 51: | Line 53: | ||
Depending on how the internet communication equipment (ie. router) is powered, the internet connection might also be temporarily lost at that time. | Depending on how the internet communication equipment (ie. router) is powered, the internet connection might also be temporarily lost at that time. | ||
- | This is not a problem, as the file is first uploaded to the [[venus-os: | + | This is not a problem, as the file is first uploaded to the [[venus-os: |
vrm_portal/remote-veconfigure.txt · Last modified: 2023-05-15 14:18 by mvader
