vrm_portal:faq
vrm_portal:faq [2016-12-19 19:41] – [What are the requirements for the Solar yield and Consumption tab?] mvader | vrm_portal:faq [2017-02-28 16:07] – [I want to analyze the data in a spreadsheet, how do I do this?] thlassche | ||
Line 22: | Line 22: | ||
These are the Solar yield and the Consumption tab on the [[https:// | These are the Solar yield and the Consumption tab on the [[https:// | ||
- | {{ : | + | Solar: |
+ | Consumption: | ||
These graphs work on information calculated by the Color Control GX, based on energy counter values read from connected devices. | These graphs work on information calculated by the Color Control GX, based on energy counter values read from connected devices. | ||
Line 51: | Line 57: | ||
* Combining MPPT Solar Chargers and PV Inverters in a system works. | * Combining MPPT Solar Chargers and PV Inverters in a system works. | ||
- | ===== How does the system overview | + | ===== How does the device list work? Old products are still showing ===== |
- | This is the system overview | + | This is the device list on the VRM Portal: |
It shows all products, their firmware version and some other additional information. After disconnecting a product from the Color Control GX or the Victron Global Remote, it is necessary to power cycle it (the CCGX or VGR). This will make the VRM Portal to empty the list and re-populate it based on the new information. | It shows all products, their firmware version and some other additional information. After disconnecting a product from the Color Control GX or the Victron Global Remote, it is necessary to power cycle it (the CCGX or VGR). This will make the VRM Portal to empty the list and re-populate it based on the new information. | ||
Line 63: | Line 69: | ||
The screensaver is disabled by default but can be configured in your profile settings to automatically show after a period of inactivity. You can also open the screensaver directly by pressing the " | The screensaver is disabled by default but can be configured in your profile settings to automatically show after a period of inactivity. You can also open the screensaver directly by pressing the " | ||
- | The screensaver displays which source of energy your site is currently running on. This is determined by looking at which source of energy (the sources being solar, generator, battery and grid) is delivering the largest amount of energy to consumers (locally connected devices using the energy). Then, if no consumers are using any power, it looks at which source provides the largest amount of energy to the battery. Then, if no battery is connected or it is not being charged, it looks at which source is delivering the most energy back to the grid. If at this point the source is still not determined, apparently no energy is being produced or used anywhere, and the state defaults to 'on grid'. | + | The screensaver displays which source of energy your installation |
Line 70: | Line 76: | ||
Open the Advanced tab, choose a date range, and then use the Download CSV or Download XLS link at the top right. | Open the Advanced tab, choose a date range, and then use the Download CSV or Download XLS link at the top right. | ||
+ | Please note: Safari is not downloading the files properly right now, please try Chrome or Firefox | ||
+ | ===== How can I remove an installation from my account? ===== | ||
- | ===== How can I remove a site from my account? ===== | + | Go to the tab Settings –> General and scroll to the bottom of that page, then click the ' |
- | Go to the tab Settings –> General and scroll to the bottom of that page, then click the ' | + | |
===== Why are some values shown red? ===== | ===== Why are some values shown red? ===== | ||
Line 87: | Line 93: | ||
===== How can I zoom out any of the graphs? ===== | ===== How can I zoom out any of the graphs? ===== | ||
- | The graphs can be zoomed out to their original zoom level by double-clicking | + | The graphs can be zoomed out to their original zoom level by clicking |
===== Why do I get such a weird high value for AC Input when a PV inverter is feeding back to the grid through the Multi? ===== | ===== Why do I get such a weird high value for AC Input when a PV inverter is feeding back to the grid through the Multi? ===== |
vrm_portal/faq.txt · Last modified: 2023-08-29 06:17 by guy_stewart
