vrm_portal:dashboard
vrm_portal:dashboard [2022-09-13 09:35] – [3.1 Inverter controls in VRM] guystewart | vrm_portal:dashboard [2023-10-10 11:50] (current) – [1.5. Details per section] sloges | ||
Line 64: | Line 64: | ||
* Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | ||
- | * Phoenix | + | * Inverter: Output power on the left axis, Battery voltage on the right axis |
* Solar Charger: Output power on the left axis, Battery voltage on the right axis. | * Solar Charger: Output power on the left axis, Battery voltage on the right axis. | ||
Requirements for the kWh production and consumption data are explained [[vrm_portal: | Requirements for the kWh production and consumption data are explained [[vrm_portal: | ||
- | Screenshot of an installation with only a Phoenix | + | Screenshot of an installation with only an Inverter, thus showing the line diagram: |
Line 131: | Line 131: | ||
==== 3.1 Inverter controls in VRM ==== | ==== 3.1 Inverter controls in VRM ==== | ||
- | Inverter controls can be made available on the VRM Dashboard, but require an additional step to enable in the Settings for that specific VRM Installation. This is to prevent accidentally switching off the system. | + | VE.Bus |
Line 143: | Line 143: | ||
- | Note - there is a limitation where these controls are not available when using a Digital Multi Control, or VE.Bus BMS v1 in the system. | + | Note - This feature is only available for VE.Bus models, is not available for VE.Direct, or VE.Can inverters. Also, there is a limitation where these controls are not available when using a Digital Multi Control, or VE.Bus BMS v1 in the system. |
==== 3.2 ESS controls in VRM ==== | ==== 3.2 ESS controls in VRM ==== | ||
vrm_portal/dashboard.1663054500.txt.gz · Last modified: 2022-09-13 09:35 by guystewart
