vrm_portal:dashboard
vrm_portal:dashboard [2021-07-30 00:47] – [1.5. Details per section] guystewart | vrm_portal:dashboard [2023-10-10 11:50] (current) – [1.5. Details per section] sloges | ||
Line 64: | Line 64: | ||
* Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | ||
- | * Phoenix | + | * Inverter: Output power on the left axis, Battery voltage on the right axis |
* Solar Charger: Output power on the left axis, Battery voltage on the right axis. | * Solar Charger: Output power on the left axis, Battery voltage on the right axis. | ||
Requirements for the kWh production and consumption data are explained [[vrm_portal: | Requirements for the kWh production and consumption data are explained [[vrm_portal: | ||
- | Screenshot of an installation with only a Phoenix | + | Screenshot of an installation with only an Inverter, thus showing the line diagram: |
Line 112: | Line 112: | ||
vrm_portal/dashboard.1627598828.txt.gz · Last modified: 2021-07-30 00:47 by guystewart
