vrm_portal:dashboard
vrm_portal:dashboard [2020-10-07 09:08] – [2.3 Requirements] guy_stewart | vrm_portal:dashboard [2023-10-10 11:50] (current) – [1.5. Details per section] sloges | ||
Line 18: | Line 18: | ||
- | ==== 1.4. Details per section ==== | + | ==== 1.5. Details per section ==== |
- | === 1.4.1 Schematic visualisation === | + | === 1.5.1 Schematic visualisation === |
Line 26: | Line 26: | ||
The information shown adapts itself to the system installed. For systems without an inverter/ | The information shown adapts itself to the system installed. For systems without an inverter/ | ||
- | === 1.4.2 Battery block === | + | === 1.5.2 Battery block === |
Line 36: | Line 36: | ||
Configuration: | Configuration: | ||
- | - Configure the battery settings on the GX Device, in the Settings | + | - Configure the battery settings on the GX Device, in the Menu → Settings |
- Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
- Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
Line 46: | Line 46: | ||
It lists all available battery measurements. Including battery monitors, but also a simple voltage measurement by a solar charger or battery charger for example. For a three output charger, it will list all three measured voltages. | It lists all available battery measurements. Including battery monitors, but also a simple voltage measurement by a solar charger or battery charger for example. For a three output charger, it will list all three measured voltages. | ||
- | For each of the available measurements, | + | The GX Device |
- to hide or show it | - to hide or show it | ||
Line 55: | Line 55: | ||
- | === 1.4.3 Historical data === | + | === 1.5.3 Historical data === |
Depending on available information, | Depending on available information, | ||
Line 64: | Line 64: | ||
* Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | ||
- | * Phoenix | + | * Inverter: Output power on the left axis, Battery voltage on the right axis |
* Solar Charger: Output power on the left axis, Battery voltage on the right axis. | * Solar Charger: Output power on the left axis, Battery voltage on the right axis. | ||
Requirements for the kWh production and consumption data are explained [[vrm_portal: | Requirements for the kWh production and consumption data are explained [[vrm_portal: | ||
- | Screenshot of an installation with only a Phoenix | + | Screenshot of an installation with only an Inverter, thus showing the line diagram: |
Line 88: | Line 88: | ||
==== 2.2 Disabling the realtime data feature ==== | ==== 2.2 Disabling the realtime data feature ==== | ||
- | Within a few weeks, a switch will be added to the Settings | + | It is possible |
+ | Examples of when you want to disable real time data are: | ||
* To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | * To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | ||
Line 110: | Line 112: | ||
vrm_portal/dashboard.1602054483.txt.gz · Last modified: 2020-10-07 09:08 by guy_stewart
