vrm_portal:dashboard
vrm_portal:dashboard [2020-09-29 08:51] – mvader | vrm_portal:dashboard [2023-10-10 11:50] (current) – [1.5. Details per section] sloges | ||
Line 18: | Line 18: | ||
- | ==== 1.4. Details per section ==== | + | ==== 1.5. Details per section ==== |
- | === 1.4.1 Schematic visualisation === | + | === 1.5.1 Schematic visualisation === |
Line 26: | Line 26: | ||
The information shown adapts itself to the system installed. For systems without an inverter/ | The information shown adapts itself to the system installed. For systems without an inverter/ | ||
- | === 1.4.2 Battery block === | + | === 1.5.2 Battery block === |
- | Intended | + | The purpose of this part of the dashboard is to show all available batteries, |
- | To see this information, the following must be done: | + | For each of the configured battery, the VRM Portal will show its name, the voltage, current, and state of charge. |
- | | + | Configuration: |
- Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | - Meet all the requirements for the Real time feature, as this information is only available when in Real time mode. See Chapter 2. | ||
- Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | - Two or more batteries must be configured. If there is just one, then the information is already shown as part of the main system overview. | ||
- | The settings in the GX Device allow configuration | + | This is the main configuration |
- | - to hide or show it | + | {{ : |
- | - to name it | + | |
- | The menu will list all available battery measurements: from all connected | + | It lists all available battery measurements. Including |
- | Here is a screen shot main menu: | + | The GX Device allows configuration of each of the available battery measurements: |
- | {{ : | + | - to hide or show it |
+ | - to name it | ||
- | And here is how to configure an entry: | + | Screenshot of detailed menu: |
- | === 1.4.3 Historical data === | + | === 1.5.3 Historical data === |
Depending on available information, | Depending on available information, | ||
Line 62: | Line 64: | ||
* Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | * Battery monitor (BMV, SmartShunt or similar): Voltage on the left axis and SOC on the right access | ||
- | * Phoenix | + | * Inverter: Output power on the left axis, Battery voltage on the right axis |
* Solar Charger: Output power on the left axis, Battery voltage on the right axis. | * Solar Charger: Output power on the left axis, Battery voltage on the right axis. | ||
Requirements for the kWh production and consumption data are explained [[vrm_portal: | Requirements for the kWh production and consumption data are explained [[vrm_portal: | ||
- | Screenshot of an installation with only a Phoenix | + | Screenshot of an installation with only an Inverter, thus showing the line diagram: |
Line 86: | Line 88: | ||
==== 2.2 Disabling the realtime data feature ==== | ==== 2.2 Disabling the realtime data feature ==== | ||
- | Within a few weeks, a switch will be added to the Settings | + | It is possible |
+ | Examples of when you want to disable real time data are: | ||
* To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | * To keep data usage to a minimum, while keeping the VRM Two way communication setting enabled to be able to remotely configure & firmware update | ||
Line 95: | Line 99: | ||
* A GX Device, with Venus OS v2.60 or later | * A GX Device, with Venus OS v2.60 or later | ||
* Good internet connection | * Good internet connection | ||
- | * Settings -> VRM Portal -> Two way communication must be enabled | ||
* Sufficient CPU resources (see below) | * Sufficient CPU resources (see below) | ||
+ | * Settings -> VRM Portal -> Two way communication must be enabled | ||
==== 2.4 GX Device CPU Load ==== | ==== 2.4 GX Device CPU Load ==== | ||
Line 105: | Line 112: | ||
vrm_portal/dashboard.1601362273.txt.gz · Last modified: 2020-09-29 08:51 by mvader
